Page 2 of 3 1 2 3
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664457
08/29/14 01:10 PM
08/29/14 01:10 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Booooooo
Re: opinion on 340 R3/w8 (358ci) [Re: SpareParts] #1664458
08/29/14 01:12 PM
08/29/14 01:12 PM
Finland
mafo Offline
mafo  Offline
Finland
I did not know that practical had anything to do with race cars
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664459
08/29/14 01:20 PM
08/29/14 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks for the info guys, I'm thinking it just wont be practical to try to fit it in the Scamp between headers and dry sump !
IF you are getting the engine at a decent price I sure
would use it.. I'd rework the K member to allow it to
fit(or get rid of the K member and go struts).. I've
been running a dry sump on my bracket car for years
with zero issues and that engine has the good parts
so you wont need to do much at all... thats a low
RPM engine for what it is
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664460
08/29/14 07:16 PM
08/29/14 07:16 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Just spoke to a friend of mine with a 65 Valiant today.
Stock stroke, sixty over 340. Running Air Wolf heads, with 273 rockers (stock no offset), .560 lift solid lifter cam (not a roller), Edelbrock manifold with a 750 Holley carb, 4.10 gear 8 3/4 rear with 26x8 slicks. Ran new best of 10.50@122 mph.
Nothing really exotic...
Figures it will go 10.30 in the "good air" coming up in the fall.
Re: opinion on 340 R3/w8 (358ci) [Re: actionange] #1664461
08/29/14 07:34 PM
08/29/14 07:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Stock stroke, sixty over 340. Running Air Wolf heads, with 273 rockers (stock no offset), .560 lift solid lifter cam (not a roller), Edelbrock manifold with a 750 Holley carb, 4.10 gear 8 3/4 rear with 26x8 slicks. Ran new best of [Email]10.50@122[/Email] mph.
What's the car weigh?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: opinion on 340 R3/w8 (358ci) [Re: B3422W5] #1664462
08/29/14 08:36 PM
08/29/14 08:36 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
What track?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: opinion on 340 R3/w8 (358ci) [Re: mafo] #1664463
08/29/14 09:50 PM
08/29/14 09:50 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You cannot discount the value of conquering a good challenge.
If the price is right , I'd find a way to make it work.
Heck , if the price is right , it would be worth buying just to have for future reference.
Re: opinion on 340 R3/w8 (358ci) [Re: tubtar] #1664464
08/29/14 09:53 PM
08/29/14 09:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Something else to consider....a lot of those roundy round motors were lightened and don't have motor mounts either.....so you'd be looking at a plate , which gives you a wee bit more room too.
Re: opinion on 340 R3/w8 (358ci) [Re: tubtar] #1664465
08/29/14 11:36 PM
08/29/14 11:36 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Yes , I just found out it does not have ears, it's a great motor but just not what I want to get involved with, I'm thinking about a 360 stroked to 426 with the Hughes kit based on 360 platform, parts are readily available and I'm more comfortable wrenching on. Plus the availability of headers etc..
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664466
08/30/14 03:01 AM
08/30/14 03:01 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What's the price of this motor?
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664467
08/30/14 10:42 AM
08/30/14 10:42 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Now I like the way you're thinking!
Re: opinion on 340 R3/w8 (358ci) [Re: pittsburghracer] #1664468
08/30/14 10:51 AM
08/30/14 10:51 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Race ready weight with driver is 2850. Car was originally a J/SA now turned bracket racer, so it is not a gutted aluminum interior, etc piece.
These numbers were recorded at Atco in NJ.
What track?
Re: opinion on 340 R3/w8 (358ci) [Re: SpareParts] #1664469
08/30/14 04:10 PM
08/30/14 04:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: opinion on 340 R3/w8 (358ci) [Re: J_BODY] #1664470
08/30/14 06:06 PM
08/30/14 06:06 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
You can get one for around 7-8k
Really not that bad
Re: opinion on 340 R3/w8 (358ci) [Re: SpareParts] #1664471
08/30/14 06:18 PM
08/30/14 06:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....not mine!!
1/2 way through my build I met up with a guy 45 miles south of me that ran a Dakota in dry lake bed races that switched to 4BT Cummins.... prior to that it was W8 small blocks. He had one used one for $3500 (complete, just add carb) and a freshened one off the dyno for $7500, once again, complete, just add carb. Both were dry sump. I understand the "used" engine sold, but the one he had freshened is still there.
Re: opinion on 340 R3/w8 (358ci) [Re: J_BODY] #1664472
08/30/14 07:33 PM
08/30/14 07:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
....not mine!!
Really a bargain when you get right down to it.
My wet sump W-9 headed deal has set me back a good bit more than 8k.
The incidentals really run up on these though......hooking up cooling , headers .......O.K. , I could have gotten by with a conventional distributor and timing chain and saved a couple G's. Maybe.
But they really deserve the show and tell factor of a belt driven cam and front mount distributor.
I'll never squeeze mine tight enough for these pieces to pay off , but they sure look pretty !
Even getting one for seven grand , you can expect to throw another couple grand at it to get it in and working I bet.
And that is with getting your hands dirty.
Re: opinion on 340 R3/w8 (358ci) [Re: tubtar] #1664473
08/31/14 01:28 AM
08/31/14 01:28 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
This motor is $13k with no carb !!
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664474
08/31/14 02:10 AM
08/31/14 02:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats about what I had in my W-9... hell I had $3500
in the dry sump with all the hoses and fittings..
plus I had a billet crank in it with CP pistons and
the 50mm cam.. and I built the headers
Re: opinion on 340 R3/w8 (358ci) [Re: J_BODY] #1664475
08/31/14 03:25 AM
08/31/14 03:25 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Wow for $3500 that would be a deal just swap the rotating assembly for as much stroke as possible in that low deck block.
Re: opinion on 340 R3/w8 (358ci) [Re: J_BODY] #1664476
08/31/14 07:06 AM
08/31/14 07:06 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
....not mine!!
Yours is a pretty big motor and I know you have $$ in the heads (I have W9's done by the same fella) but you made something like 760 IIRC at 436" (?) that's nothing to laugh at by any means but a lot of these small cube high rpm W8 motors make around 2hp/ CI in my opinion that is quite an impressive task. 364" 9:1 made 733. I do however wonder what the dry sump is worth on the time slip.
Page 2 of 3 1 2 3
