Page 3 of 3 1 2 3
Re: opinion on 340 R3/w8 (358ci) [Re: SpareParts] #1664477
08/31/14 10:52 AM
08/31/14 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yours is a pretty big motor and I know you have $$ in the heads (I have W9's done by the same fella) but you made something like 760 IIRC at 436" (?) that's nothing to laugh at by any means but a lot of these small cube high rpm W8 motors make around 2hp/ CI in my opinion that is quite an impressive task. 364" 9:1 made 733. I do however wonder what the dry sump is worth on the time slip.
The dry sump does make more power.. its been proven
on the dynos.. it has a larger effect on larger engines
but I cant say what the time slip would say.. due
to the chassis set up... the vac part of the pump is
a big factor, as is the no oil in the pan(very little)
Re: opinion on 340 R3/w8 (358ci) [Re: littleVAL] #1664478
08/31/14 12:24 PM
08/31/14 12:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wow for $3500 that would be a deal just swap the rotating assembly for as much stroke as possible in that low deck block.
I know..... I just had too much on my plate finishing my car to buy it. For that money the dry sump would have cost that much.
Page 3 of 3 1 2 3
