Re: opinion on 340 R3/w8 (358ci)
[Re: 340KID]
#1664459
08/29/14 01:20 PM
08/29/14 01:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks for the info guys, I'm thinking it just wont be practical to try to fit it in the Scamp between headers and dry sump !
IF you are getting the engine at a decent price I sure would use it.. I'd rework the K member to allow it to fit(or get rid of the K member and go struts).. I've been running a dry sump on my bracket car for years with zero issues and that engine has the good parts so you wont need to do much at all... thats a low RPM engine for what it is
[Re: 340KID]
#1664460
08/29/14 07:16 PM
08/29/14 07:16 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Just spoke to a friend of mine with a 65 Valiant today. Stock stroke, sixty over 340. Running Air Wolf heads, with 273 rockers (stock no offset), .560 lift solid lifter cam (not a roller), Edelbrock manifold with a 750 Holley carb, 4.10 gear 8 3/4 rear with 26x8 slicks. Ran new best of 10.50@122 mph. Nothing really exotic... Figures it will go 10.30 in the "good air" coming up in the fall.
[Re: actionange]
#1664461
08/29/14 07:34 PM
08/29/14 07:34 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Just spoke to a friend of mine with a 65 Valiant today. Stock stroke, sixty over 340. Running Air Wolf heads, with 273 rockers (stock no offset), .560 lift solid lifter cam (not a roller), Edelbrock manifold with a 750 Holley carb, 4.10 gear 8 3/4 rear with 26x8 slicks. Ran new best of [Email]10.50@122[/Email] mph. Nothing really exotic... Figures it will go 10.30 in the "good air" coming up in the fall.
What's the car weigh?
[Re: mafo]
#1664463
08/29/14 09:50 PM
08/29/14 09:50 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I did not know that practical had anything to do with race cars
You cannot discount the value of conquering a good challenge. If the price is right , I'd find a way to make it work. Heck , if the price is right , it would be worth buying just to have for future reference.
[Re: 340KID]
#1664467
08/30/14 10:42 AM
08/30/14 10:42 AM
actionange
anywhere@ anytime
Yes , I just found out it does not have ears, it's a great motor but just not what I want to get involved with, I'm thinking about a 360 stroked to 426 with the Hughes kit based on 360 platform, parts are readily available and I'm more comfortable wrenching on. Plus the availability of headers etc..
Now I like the way you're thinking!
[Re: pittsburghracer]
#1664468
08/30/14 10:51 AM
08/30/14 10:51 AM
actionange
anywhere@ anytime
Race ready weight with driver is 2850. Car was originally a J/SA now turned bracket racer, so it is not a gutted aluminum interior, etc piece.
These numbers were recorded at Atco in NJ.
What track?
[Re: SpareParts]
#1664469
08/30/14 04:10 PM
08/30/14 04:10 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
What's the price of this motor?
[Re: J_BODY]
#1664470
08/30/14 06:06 PM
08/30/14 06:06 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
You can get one for around 7-8k
Really not that bad
[Re: J_BODY]
#1664472
08/30/14 07:33 PM
08/30/14 07:33 PM
tubtar
St. Paul , Mn.
....not mine!!
1/2 way through my build I met up with a guy 45 miles south of me that ran a Dakota in dry lake bed races that switched to 4BT Cummins.... prior to that it was W8 small blocks. He had one used one for $3500 (complete, just add carb) and a freshened one off the dyno for $7500, once again, complete, just add carb. Both were dry sump. I understand the "used" engine sold, but the one he had freshened is still there.
Really a bargain when you get right down to it. My wet sump W-9 headed deal has set me back a good bit more than 8k. The incidentals really run up on these though......hooking up cooling , headers .......O.K. , I could have gotten by with a conventional distributor and timing chain and saved a couple G's. Maybe. But they really deserve the show and tell factor of a belt driven cam and front mount distributor. I'll never squeeze mine tight enough for these pieces to pay off , but they sure look pretty ! Even getting one for seven grand , you can expect to throw another couple grand at it to get it in and working I bet. And that is with getting your hands dirty.
[Re: 340KID]
#1664474
08/31/14 02:10 AM
08/31/14 02:10 AM
MR_P_BODY
This motor is $13k with no carb !!
Thats about what I had in my W-9... hell I had $3500 in the dry sump with all the hoses and fittings.. plus I had a billet crank in it with CP pistons and the 50mm cam.. and I built the headers
[Re: J_BODY]
#1664476
08/31/14 07:06 AM
08/31/14 07:06 AM
SpareParts
Janesville, WI
....not mine!!
Yours is a pretty big motor and I know you have $$ in the heads (I have W9's done by the same fella) but you made something like 760 IIRC at 436" (?) that's nothing to laugh at by any means but a lot of these small cube high rpm W8 motors make around 2hp/ CI in my opinion that is quite an impressive task. 364" 9:1 made 733. I do however wonder what the dry sump is worth on the time slip.
