NC street outlaws
#1664118
08/26/14 10:43 PM
08/26/14 10:43 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Roxboro This weekend August 29&30. Open to all states. Who has the baddest street car.
I plan to be there representing Mopar. Probably the only one. Gonna let it all hang out on the no prep surface.
Re: Roxboro NC street outlaws
[Re: Leon441]
#1664120
08/26/14 10:58 PM
08/26/14 10:58 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Leon have you put the NOS on it yet? Or are you just going NA ?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: J_BODY]
#1664122
08/26/14 11:37 PM
08/26/14 11:37 PM
Leon441
Lynchburg, VA
Been spraying a 36 in the plate and a 20 in the fogger. Responding well. Stepped up the plate. And plan to creep up on the fogger
[Re: Leon441]
#1664126
08/27/14 12:24 AM
08/27/14 12:24 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Go get em Leon! I'm sure you will do well. Don
[Re: Leon441]
#1664127
08/27/14 12:46 AM
08/27/14 12:46 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
How well?
What ever happened to Junior French? This would be right up his alley
[Re: SpareParts]
#1664128
08/27/14 03:28 AM
08/27/14 03:28 AM
Posts: 860 lancaster,california
johnnycuda
Good luck Leon!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Leon441]
#1664129
08/27/14 09:51 AM
08/27/14 09:51 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Show 'em how it's done! Good luck!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Leon441]
#1664131
08/27/14 10:11 AM
08/27/14 10:11 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Hope it goes better than the race they attempted to do at Darlington back in May...they had about 3 cars show up. No one around here wants to run on an unprepped surface...including me. Hardly a test of who has the baddest "street car".
Any of the cars around this area that are set up to run on an unprepped surface will not go to the track, let alone run eliminations. They are grudge cars.
I get what they are doing...playing off the TV show and all. That's cool and I hope it does well.
[Re: 1967dartgt]
#1664133
08/27/14 01:29 PM
08/27/14 01:29 PM
Leon441
Lynchburg, VA
.036 Prock double cross plate. There is nothing keeping one from running a .016 in a plate. I have flowed them with tiny pills and big pills. Ideally you want smaller holes or less holes for small jets. More holes for more jet. When you have small jets for a given bar nitrous will spray hard on the near end when it first hits then even out. When you spray big jets for the bar it will dead head and spray harder on the far end of the bar. That's why I bench spray before going on the motor.
[Re: Leon441]
#1664134
08/27/14 02:23 PM
08/27/14 02:23 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So you are spraying two 36s and about 125-150hp on the plate. With another 150hp in fogger.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: SpareParts]
#1664136
08/27/14 10:09 PM
08/27/14 10:09 PM
Posts: 2,601 ky
headhunter
ky
How well?
hes still around
