Page 2 of 3 1 2 3
Re: 1100+ HP engine combinations what would you build? [Re: sdaurity] #1663345
08/26/14 04:33 PM
08/26/14 04:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First thing.. is it 1/8 mile or 1/4... turboed engines
tend to work better on the 1/4.. spray tends to work
better on the 1/8
Dude its not 1994 any power adder will do just fine. 100ft or 1/4 mile doesnt matter.
I dis-agree.. turbos are better on the 1/4
Re: 1100+ HP engine combinations what would you build? [Re: MR_P_BODY] #1663346
08/26/14 06:38 PM
08/26/14 06:38 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
better on the 1/8
So this is based on personal car and tuning experience? I would love to see pics of your nitrous, supercharged, and turbo car/cars. I assume they were all blow-thru on the forced induction ones since you had such a time picking a fuel injection system a few weeks back?
One day I will have something cool here.
Re: 1100+ HP engine combinations what would you build? [Re: sdaurity] #1663347
08/26/14 06:47 PM
08/26/14 06:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
better on the 1/8
I've built different cars, turbo and blown... but
I also see cars at the track... just because I am
just now going to injection you think I dont know..
think what you want
Re: 1100+ HP engine combinations what would you build? [Re: MR_P_BODY] #1663348
08/26/14 07:24 PM
08/26/14 07:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I never get why you can run N2O on a BB but not boost. You can do a 300 plate system. What's the difference? It's so stupid....I mean BB SB what have you; it all cost MONEY. The difference is tiny, I get the tire/suspention aspect but not the BB vs SB junk. You can make a SB 450+CID.
Re: 1100+ HP engine combinations what would you build? [Re: Mr.Yuck] #1663349
08/26/14 08:37 PM
08/26/14 08:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im saving my like new 6.1 crank for later down the road a 5.7 single turbo cheap engine.
Mopar to the bone!!!
Re: 1100+ HP engine combinations what would you build? [Re: SLEDGEHAMMER] #1663350
08/26/14 11:12 PM
08/26/14 11:12 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
I've been 5.30 at 132 with 440-1 heads and nitrous. 3350 lbs, I would say that's a little more than 1100 hp. Build a big block , b1 originals or mc, throw on some nitrous, I'd say you can make pretty close to 1000 on motor alone. Make sure you get the " correct" cam and have the right person prepare the heads for nitrous use....they need a little help in certain areas.
Do you plan on running ultra street .?
....BAD A$$ STREET CAR.....
Re: 1100+ HP engine combinations what would you build? [Re: n20mstr] #1663351
08/27/14 09:27 AM
08/27/14 09:27 AM
small block Mopars and Boost is not the best plan--4 bolts per cylinder on the head is not good for forced induction--poor idea IMO
Run from that go big block
Re: 1100+ HP engine combinations what would you build? [Re: ] #1663352
08/27/14 09:32 AM
08/27/14 09:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You do know race blocks are 6 bolt. And any motor you build at this hp level needs to be a aftermarket block, big or small.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 1100+ HP engine combinations what would you build? [Re: 1967dartgt] #1663353
08/27/14 10:31 AM
08/27/14 10:31 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
This is why these threeads make me want to pull my hair out. Not a clue and giving advise.
Re: 1100+ HP engine combinations what would you build? [Re: Mr.Yuck] #1663354
08/27/14 10:40 AM
08/27/14 10:40 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You can run bb and boost, you have to run outlaw 275 or outlaw drag radial. You do know they run 900 cu in big blocks on spray and 670 cu in on boost in theses two classes, how do you think a small block would stand up?
Re: 1100+ HP engine combinations what would you build? [Re: sdaurity] #1663355
08/27/14 11:09 AM
08/27/14 11:09 AM
jersey
Spaceman Spiff Offline
jersey
And what car is yours? What power adder? What it run?
Please share your advise wise one. You seem to know it all.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 1100+ HP engine combinations what would you build? [Re: Spaceman Spiff] #1663356
08/27/14 11:15 AM
08/27/14 11:15 AM
nc
cold85 Offline
cold85  Offline
nc
I think everyone is missing the biggest question its not about how much power.
What class are you looking to run? if its x275 then you are wasting time with a bb mopar. if its outlaw then what are the rules. Sure many combinations will make 1100 but if you are talking about a heads up class then rules and weights play a bigger part than anything
Re: 1100+ HP engine combinations what would you build? [Re: Spaceman Spiff] #1663357
08/27/14 11:21 AM
08/27/14 11:21 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 1100+ HP engine combinations what would you build? [Re: OUTLAWD] #1663358
08/27/14 11:32 AM
08/27/14 11:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
And it was small block w8 nitrous powered.
Re: 1100+ HP engine combinations what would you build? [Re: 1967dartgt] #1663359
08/27/14 11:33 AM
08/27/14 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Then run a BB, they both cost TONS of money. Which was my point. Isn't it all about going fast?
"I am looking at the radial classes where the limitation has been pretty much BB are limited to nitrous"
Re: 1100+ HP engine combinations what would you build? [Re: cold85] #1663360
08/27/14 11:35 AM
08/27/14 11:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I don't think 1100 hp would be competitive in any of the heads up classes.
Re: 1100+ HP engine combinations what would you build? [Re: 1967dartgt] #1663361
08/27/14 12:02 PM
08/27/14 12:02 PM
nc
cold85 Offline
cold85  Offline
nc
Maybe ultra
Re: 1100+ HP engine combinations what would you build? [Re: OUTLAWD] #1663362
08/27/14 12:08 PM
08/27/14 12:08 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Forged 6.1 Hemi, Stock 6.4 or 6.1 heads with Ti retainers, GOOD springs and rocker shaft tie downs, off the shelf TTI headers and a Procharger F1, Vortech Outlaw blower, KB 2.8 or a single GT45 etc turbo....
Splurge on the fuel system and you could even have AC and drive it on the street.
MS3x engine management by www.EFIsource.com
If you'd like me to outline it part by part and have any detailed questions, ask away.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 1100+ HP engine combinations what would you build? [Re: Mr.Yuck] #1663363
08/27/14 12:54 PM
08/27/14 12:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
This is x275 that you are talking about. If you want to run bb with boost there are classes was my point. So its like this Ultra 5.00 ets, x275 4.50 ets, outlaw 275 4.20 ets and outlaw drag radial with 4.00 ets. Pick what class your wallet can afford and build a combo to those rules.
Re: 1100+ HP engine combinations what would you build? [Re: AlexP] #1663364
08/27/14 12:56 PM
08/27/14 12:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Now you know why I built my turbo car for me and not a "Class"
Small tires and heavy cars are not what I like. I'd rather build what I like and have fun test and tuning, then be an also ran.
It's light and has plenty of tire.
I think we need to start the "Front Runner Nationals"
Rules are you must be over 5000#
You must run a Weld 3.5 wide front wheel on the back
Any 24 inch front runner tire
And must have a bigger slick on the front wheels then your rear tire.
And no power management.
Ha ha ha
There's prolly someone already in the 3's with this combo ha ha ha
Page 2 of 3 1 2 3
