Re: New best time! Update video added
[Re: Wicked49670dart]
#1662850
08/27/14 03:24 PM
08/27/14 03:24 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Congrats on your new best! ![](/ubbthreads/images/graemlins/beer.gif) Good looking car. Mark ![](/ubbthreads/images/graemlins/thumbs.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
#1662855
08/28/14 10:21 AM
08/28/14 10:21 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Just curious, but what plate and solenoids? If you don't mind sharing?
[Re: an8sec70cuda]
#1662856
08/28/14 11:38 AM
08/28/14 11:38 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
What kind of cam is that? I run stage VI heads and have a Doug Herbert solid roller that 272-275 @50 and 620 lift. very similar setup as yours. What size converter is in it? mines 3800 lbs and runs 10.50's - 10.60 on the motor. Very sweet. I also run 3.91 gears with a 28" tire. I know on my setup it doesnt like high revs, if I shift it between 6300 and 6800 it runs exactly the same.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1662857
08/28/14 12:01 PM
08/28/14 12:01 PM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
The cam is Hughes 272@.050 /.620 solid lifter. I run a 4.56 gear on 30x13.50x15 MT streets. I shift at 6500 and cross at 7000.Converter is a 10" Turbo Action Nitrous 3800 that flashes to 5000 on motor and 6000 on Nitrous.
[Re: RobX4406]
#1662859
08/28/14 06:23 PM
08/28/14 06:23 PM
dragram440
bigfork mn
For being so close to my combo it sure seems like a lot of gear and rpm for that setup. I run a 8" coan 5000 converter. Im 400lbs heavier and have less gear same compression, my cam is a solid roller but same specs. What carb is on it? Do the heads have much port work done to them? Are they standard or max wedge ports?
67' charger 499 RB
10.57 at 127
[Re: RobX4406]
#1662860
08/28/14 06:42 PM
08/28/14 06:42 PM
Posts: 1,553 baldwinsville new york
a493demon
That's a pretty big n/f spread using std bottle pressures in the 900 range. If that is a fresh start, I'd be closer to a 10-12 spread, 6-10* of timing pulled and start leaning it out until it slowed down. Then start feeding timing back in.
Car runs well and looks great.
I'm guessing the big spread from the higher fuel PSI ? I ran 6 lbs and had a 13 spread but prob. could have went a little more of a spread.
#1662863
08/29/14 12:37 AM
08/29/14 12:37 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
The Nitrous kit is a Induction Solution kit that is jetted and flowed from him, the carb is a 1000cfm 4150 from Pro-Systems jetted for my engine!
I'd send Steve a copy of your in car video where you smacked it. Sounds and acts a lot like a lean surge. You can hear it begin at the top of second gear. If you have an A/F meter see what that tells you.
You run it like that for extended periods and you'll likely hurt something. Hate to see that happen.
[Re: dragram440]
#1662864
08/29/14 12:37 AM
08/29/14 12:37 AM
Wicked49670dart
Oak Harbor, WA
For being so close to my combo it sure seems like a lot of gear and rpm for that setup. I run a 8" coan 5000 converter. Im 400lbs heavier and have less gear same compression, my cam is a solid roller but same specs. What carb is on it? Do the heads have much port work done to them? Are they standard or max wedge ports? [/quote
My Stage VI has port work but never flowed with standard ports 2.14/1.81. What are your 60ft and 660ft times? A 10" Nitrous converter verses a 8" converter may react differently in the same situation or car.
#1662866
08/29/14 01:14 AM
08/29/14 01:14 AM
RobX4406
I did have Steve look at the video, but he is having a family issue and did not want to bug with this right now. I thought I would throw the problem out to you guys for your ideas. Thanks guys for your comments.Matt
Family first!
Hope everything works out well for Steve/Family.
He will get you fixed up.
[Re: dragram440]
#1662868
08/29/14 10:32 PM
08/29/14 10:32 PM
Wicked49670dart
Oak Harbor, WA
I leave off of foot brake basically from a idle, It runs 1.47 to 1.49 60'. I normally shift between 6300 and 6500 and trap at 6500. Im not real sure what my heads flow either I bought them off Ebag. They are std. port and valves. Nice car and congrats. I like to talk to people running these heads just to see how they are working for them. For all the bad you read about them they seem to work pretty good. I am running the matching M1 intake and a 1050 dominator. My converter was actually built for my ram I was racing and set up for nitrous but I havent run any on this setup.
I leave the same also off idle, has the quickest 60ft. My NA pass has a 1.46 60ft and 1.34 on Nitrous. I use a Edelbrock Victor 440 RB manifold on my low deck motor. Any pics of your car?
