Re: 273 building and info needed PLEASE!
[Re: MuuMuu101]
#1661706
08/23/14 05:52 PM
08/23/14 05:52 PM
Posts: 16,210 Mesa, Arizona
dart4forte
Mesa, Arizona
This is all interesting as I've got a 273 in my Dart that's tired and a standard bore '68 block in my garage.
I am following your build. I would stay with the 273 if it were my car. I think I have some standard bore pistons laying around. I also have some .060 forged pistons as well.
[Re: dart4forte]
#1661707
08/23/14 09:49 PM
08/23/14 09:49 PM
RapidRobert
Light rods (floaters) & new eBay bushings
[Re: ronhug]
#1661709
08/23/14 10:27 PM
08/23/14 10:27 PM
dart4forte
Mesa, Arizona
so here's what its looking like, 273, with later model light rods, swirl port heads milled 0.05 and ported to a stock 360 four barrel intake, maybe 2.02 and 1.78 valves. stock 318 roller lifters. and a cam with a 340 HP profile. its a "guy" thing why build a 273 ? cause we can !!! I'm rebuilding my first car, it was a 64 barracuda four speed 273, my brother and I drove variants and Barracuda through our youth, we bucked the GM tied. my beater stock 273 lost most street races but I did win a few out of maybe nothing more then bigger balls. so out of love and respect for my first car the 273 has to stay, So to all of you that have commented please continue to do so your help is greatly appreciated and needed. (oh and as a reminder this is a "low-buck" project)
I assume you will have the machine work done by a local shop. You may want take some measurements such as deck height, how far the pistons are in the hole etc. before taking anything off both the heads and the deck.
[Re: dart4forte]
#1661710
08/23/14 11:06 PM
08/23/14 11:06 PM
Posts: 23,554 Here
jcc
No soup for you!!!
No soup for you!!!
Here
2.02 valves in a 273, why? And how much notch/shrouding are you willing to accept?
I'm with Helmuth Hübener, and no soup is being served today.
[Re: dart4forte]
#1661715
08/24/14 02:48 AM
08/24/14 02:48 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I'm really uncertain. I kind of want to save the 273 for another project. I was thinking something along the lines of an Early-A. Something like a cruiser Dart or Valiant wagon or a Trans Am "like" car for a 63-65 Dart or Barracuda.
They made .060" over pistons for the 273? Can the block handle that kind of bore? That definitely sounds interesting. You think you can make a 91 octane engine with those?
[Re: dart4forte]
#1661717
08/24/14 03:37 AM
08/24/14 03:37 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I have the specs on the pistons vs different head gasket and head CC combinations. My last 273 was .060 over. No problems.
The pistons are the old school Badgers. The tops have been machined to get the cr down plus they are a little lighter
.060 over, some head work, and a good intake with a 4-barrel carb should wake up a 273 quite a bit and make it run pretty nicely.
[Re: MuuMuu101]
#1661718
08/24/14 03:40 AM
08/24/14 03:40 AM
dart4forte
Mesa, Arizona
That and depending the trans with some 3.55s to 3.91s it will be a little screamer.
[Re: ronhug]
#1661719
08/24/14 11:47 AM
08/24/14 11:47 AM
Posts: 23,554 Here
jcc
No soup for you!!!
No soup for you!!!
Here
"so here's what its looking like, 273, with later model light rods, swirl port heads milled 0.05 and ported to a stock 360 four barrel intake, maybe 2.02 and 1.78 valves." Quote:
im surprised im plowing new ground here? i really thought someone had been down this road and would share their knowledge, the valve size was intended to be more a question, but yes talking out loud here may need more clearance cut then could be sustained,
273 Std bore is 3.625, combined valve dim is 3.8, that would be fairly new ground.
Rather then just bore the 273 .060, I'd go .285 over.
I have in one of my cars a warmed over 273, I am very surprised at how peppy it is for a 273, but if great mileage is any concern, mine would not make you happy, and I would never build one.
[Re: jcc]
#1661720
08/24/14 05:58 PM
08/24/14 05:58 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Lol... 273 bored .285 over...
I'm curious what the Trans AM guys racing the 273's in Early A's did to their engines. Probably a lot of custom work.
[Re: MuuMuu101]
#1661721
08/24/14 08:00 PM
08/24/14 08:00 PM
dart4forte
Mesa, Arizona
You can expect a stock/super stock 273 to come in around 30k. A lot of money for a 273. Of course everything is flow enhanced. I've only seen one transam 273 but that was in a nostalgia car.
[Re: dart4forte]
#1661723
08/24/14 09:52 PM
08/24/14 09:52 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I don't think I've got $30k for a 273... Let me check my pockets... Nope... Machining and labor included how costly would it be to build a 300+ horsepower 273? I mean,if I'm not mistaken, the D-Dart pulled 275 hp apparently with a larger cam, headers, and a 4-barrel.
