Page 2 of 3 1 2 3
Re: 273 building and info needed PLEASE! [Re: MuuMuu101] #1661706
08/23/14 05:52 PM
08/23/14 05:52 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
This is all interesting as I've got a 273 in my Dart that's tired and a standard bore '68 block in my garage.
I am following your build. I would stay with the 273 if it were my car. I think I have some standard bore pistons laying around. I also have some .060 forged pistons as well.
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661707
08/23/14 09:49 PM
08/23/14 09:49 PM
Light rods (floaters) & new eBay bushings
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661708
08/23/14 09:53 PM
08/23/14 09:53 PM
Nebraska
ronhug Offline OP
ronhug  Offline OP
Nebraska
so here's what its looking like, 273, with later model light rods, swirl port heads milled 0.05 and ported to a stock 360 four barrel intake, maybe 2.02 and 1.78 valves. stock 318 roller lifters. and a cam with a 340 HP profile.
its a "guy" thing why build a 273 ? cause we can !!! I'm rebuilding my first car, it was a 64 barracuda four speed 273, my brother and I drove variants and Barracuda through our youth, we bucked the GM tied.
my beater stock 273 lost most street races but I did win a few out of maybe nothing more then bigger balls. so out of love and respect for my first car the 273 has to stay, So to all of you that have commented please continue to do so your help is greatly appreciated and needed. (oh and as a reminder this is a "low-buck" project)
Re: 273 building and info needed PLEASE! [Re: ronhug] #1661709
08/23/14 10:27 PM
08/23/14 10:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I assume you will have the machine work done by a local shop. You may want take some measurements such as deck height, how far the pistons are in the hole etc. before taking anything off both the heads and the deck.
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661710
08/23/14 11:06 PM
08/23/14 11:06 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
2.02 valves in a 273, why? And how much notch/shrouding are you willing to accept?
I'm with Helmuth Hübener, and no soup is being served today.
Re: 273 building and info needed PLEASE! [Re: jcc] #1661711
08/24/14 12:29 AM
08/24/14 12:29 AM
Nebraska
ronhug Offline OP
ronhug  Offline OP
Nebraska
im surprised im plowing new ground here? i really thought someone had been down this road and would share their knowledge, the valve size was intended to be more a question, but yes talking out loud here may need more clearance cut then could be sustained,
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661712
08/24/14 12:32 AM
08/24/14 12:32 AM
Nebraska
ronhug Offline OP
ronhug  Offline OP
Nebraska
just posted pretty much the same reply... I am suprised, it seems im plowing new ground, has anyone ever put 318 swirl port heads on a 273?
did they mill them ? please share if anyone has this knowledge.
Re: 273 building and info needed PLEASE! [Re: ronhug] #1661713
08/24/14 12:52 AM
08/24/14 12:52 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Only mill heads if they need it or you need to bring the deck within certain specs to match how far the piston is in the bore, gasket thickness etc. Talk with an engine builder.
Have you torn the engine apart yet.
Re: 273 building and info needed PLEASE! [Re: jcc] #1661714
08/24/14 01:23 AM
08/24/14 01:23 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
What I did with my 273 I I went with a 920 casting, used 1.88 stainless valves and cut them down to 1.84. The block was taken .030.
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661715
08/24/14 02:48 AM
08/24/14 02:48 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'm really uncertain. I kind of want to save the 273 for another project. I was thinking something along the lines of an Early-A. Something like a cruiser Dart or Valiant wagon or a Trans Am "like" car for a 63-65 Dart or Barracuda.
They made .060" over pistons for the 273? Can the block handle that kind of bore? That definitely sounds interesting. You think you can make a 91 octane engine with those?
Re: 273 building and info needed PLEASE! [Re: MuuMuu101] #1661716
08/24/14 03:25 AM
08/24/14 03:25 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have the specs on the pistons vs different head gasket and head CC combinations. My last 273 was .060 over. No problems.
The pistons are the old school Badgers. The tops have been machined to get the cr down plus they are a little lighter
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661717
08/24/14 03:37 AM
08/24/14 03:37 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
.060 over, some head work, and a good intake with a 4-barrel carb should wake up a 273 quite a bit and make it run pretty nicely.
Re: 273 building and info needed PLEASE! [Re: MuuMuu101] #1661718
08/24/14 03:40 AM
08/24/14 03:40 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
That and depending the trans with some 3.55s to 3.91s it will be a little screamer.
Re: 273 building and info needed PLEASE! [Re: ronhug] #1661719
08/24/14 11:47 AM
08/24/14 11:47 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
"so here's what its looking like, 273, with later model light rods, swirl port heads milled 0.05 and ported to a stock 360 four barrel intake, maybe 2.02 and 1.78 valves."
273 Std bore is 3.625, combined valve dim is 3.8, that would be fairly new ground.
Rather then just bore the 273 .060, I'd go .285 over.
I have in one of my cars a warmed over 273, I am very surprised at how peppy it is for a 273, but if great mileage is any concern, mine would not make you happy, and I would never build one.
Re: 273 building and info needed PLEASE! [Re: jcc] #1661720
08/24/14 05:58 PM
08/24/14 05:58 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Lol... 273 bored .285 over...
I'm curious what the Trans AM guys racing the 273's in Early A's did to their engines. Probably a lot of custom work.
Re: 273 building and info needed PLEASE! [Re: MuuMuu101] #1661721
08/24/14 08:00 PM
08/24/14 08:00 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You can expect a stock/super stock 273 to come in around 30k. A lot of money for a 273. Of course everything is flow enhanced. I've only seen one transam 273 but that was in a nostalgia car.
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661722
08/24/14 09:43 PM
08/24/14 09:43 PM
Nebraska
ronhug Offline OP
ronhug  Offline OP
Nebraska
can you share the specs ?
Re: 273 building and info needed PLEASE! [Re: dart4forte] #1661723
08/24/14 09:52 PM
08/24/14 09:52 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I don't think I've got $30k for a 273... Let me check my pockets... Nope... Machining and labor included how costly would it be to build a 300+ horsepower 273? I mean,if I'm not mistaken, the D-Dart pulled 275 hp apparently with a larger cam, headers, and a 4-barrel.
Re: 273 building and info needed PLEASE! [Re: MuuMuu101] #1661724
08/24/14 10:01 PM
08/24/14 10:01 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I haven't denied mine but I'm thinking May 300 to the rear wheels. My 273 has a lot of trick thinks like low ring tension, offset balance, head porting and work on the runners. We were able to get 116% port velocity and about 168 in flow. That's with a 920 head, stainless 1.88 valves cut down to 1.84.
Re: 273 building and info needed PLEASE! [Re: RapidRobert] #1661725
08/25/14 12:53 AM
08/25/14 12:53 AM
Nebraska
ronhug Offline OP
ronhug  Offline OP
Nebraska
those stock rods ? what year motor ?
Page 2 of 3 1 2 3
