Page 2 of 3 1 2 3
Re: Best smallblock head w/stock exaust pattern [Re: Ian] #1661142
08/20/14 07:45 PM
08/20/14 07:45 PM
ont,canada
mopartuner Offline OP
ont,canada
I was just trying to see whats out there.My current combo runs ok for what it is.I have to make a call on a torque converter and just deciding to change the motor or leave it as is and work with it.I have flowed my heads and they were 268 cfm @ 600 lift.I ported these and they seem (for a home job) they work ok.My combo is a 410 10.5 to 1 (180psi)with a flat tappet solid cam.My car is 3150# w/driver.I have been 123.77 mph with this set up.My best et is 10.95 w/1.53 60 ft.How fast can a car go if it runs 122-123 mph in the quarter?This is pump gas w/mufflers.
410 pump gas solis flat tappet cam 10.95 so far
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661143
08/20/14 07:49 PM
08/20/14 07:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Your about there.......... Maybe a little more room
I went about 124 at 10.74 in an old Eddie head flat tappet combo...... 3400 race weight with a 727
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661144
08/20/14 07:57 PM
08/20/14 07:57 PM
ont,canada
ont,canada
Oh I think there is some room there,the 60 ft suks
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661145
08/20/14 08:05 PM
08/20/14 08:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep, at that weight it's very possible to knock a tenth out of that 60 foot. I went 1.44 with what I had, with about a point more compression but good bit more weight.
My eddies went 274@ 600 stage two job Hensley did,.... Picking up 60 foot will really help the whole time slip
1.41 best 60 foot
6.56 at 104.17
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661146
08/21/14 09:43 AM
08/21/14 09:43 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
When my Barracuda was on pump gas it ran 10.79 @ 123 with a 1.49-1.47 60' time. This is with a 410, 10.8:1 comp, pump gas, small street roller, through the mufflers, 3250 lbs. You could make nice gains if you can pick up the 60' times about 5 hundredths. I would go to a TNT and try different pump cams and squirters on the carb to get the 60' times down.
For what its worth, my ported eddy's flow 293 @ .600...but my cam is only .550 ish lift. I switched to e85 and the car picked up a CHUNK of ET. Now its in the mid 10's, and should be in the 10.4x's this fall.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661147
08/21/14 02:21 PM
08/21/14 02:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
http://www.j-performance.com/index.php?option=com_content&task=view&id=59
Don't know why we are not seeing more testing on these yet, they been out for a while
312 @ .600 lift? Even more flow if you want to go crazy big cam
Re: Best smallblock head w/stock exaust pattern [Re: HotRodDave] #1661148
08/21/14 03:04 PM
08/21/14 03:04 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I may be wrong, and hate to see it happen to anybody but I thought Dr.J's porting went out of business not long ago?
I thought it had been posted here but I can't find it. Maybe a rumor somebody started?
Re: Best smallblock head w/stock exaust pattern [Re: fishy340] #1661149
08/21/14 04:17 PM
08/21/14 04:17 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
my 360-1 cnc heads, stock and w-2 exhaust patterns
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Best smallblock head w/stock exaust pattern [Re: slammedR/T] #1661150
08/21/14 08:06 PM
08/21/14 08:06 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My 360-2 cnc heads are that way also..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Best smallblock head w/stock exaust pattern [Re: D-50] #1661151
08/21/14 09:36 PM
08/21/14 09:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I believe that is because w2 headers had 2 different bolt patterns if I remember correctly if you hold up a standard exhaust gasket the ports don't line up.
but its been a while since I was playing with w2s
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Best smallblock head w/stock exaust pattern [Re: dusturbd340W5] #1661152
08/21/14 09:42 PM
08/21/14 09:42 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My ported Eddys flowed just shy of 300 @ .600 on one bench and just over on another.
My best ET is 11.36 @ 118 in a 3400 lb tuck at 7600' DA.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Best smallblock head w/stock exaust pattern [Re: Adobedude] #1661153
08/21/14 10:12 PM
08/21/14 10:12 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Just a Tease
Re: Best smallblock head w/stock exaust pattern [Re: Adobedude] #1661154
08/21/14 10:48 PM
08/21/14 10:48 PM
slammedR/T Offline
slammedR/T  Offline
my ported Edelbrock magnum heads were like 305 cfm on champion racing heads flow bench out of palm coast.
racemagnum
Re: Best smallblock head w/stock exaust pattern [Re: slammedR/T] #1661155
08/21/14 11:20 PM
08/21/14 11:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMO the next step after Edelbrocks are indys, if I do another small block that's what I'll use. My Edelbrocks went 293 @ .650 on Curtis Boggs bench with 2.02 valves, they have 2.05" in them now. My 10.9-1 408 with a flat solid cam has ran a best of 6.57 @ 104 with a 1.38 60' uncorked and 6.70 with a 1.41 60' in street trim on pump 93 at 3260 pounds.
Re: Best smallblock head w/stock exaust pattern [Re: dusturbd340W5] #1661156
08/22/14 12:43 AM
08/22/14 12:43 AM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I believe you are right
It will work ok on a bracket car with cheap gaskets and red high temp rtv
I wouldnt do it on a street car.
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661157
08/22/14 12:48 AM
08/22/14 12:48 AM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I run 360-2"s with cheap 1 5/8th headers. It is temporary until I save up for some tti"s
Re: Best smallblock head w/stock exaust pattern [Re: slammedR/T] #1661158
08/22/14 01:35 AM
08/22/14 01:35 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Stock header bolt location yes...But far from a stock exhaust port.
J,X or eddie, and pro comp is a stock exhaust port.I wish i could post pictures.
Re: Best smallblock head w/stock exaust pattern [Re: fishy340] #1661159
08/22/14 02:47 AM
08/22/14 02:47 AM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I'm agreeing with you. If he has to retain stock exh. Flange
I would not use the Indy heads
I don't know which would be best. I've seen several cars run great with the eddies
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661160
08/22/14 08:06 AM
08/22/14 08:06 AM
Victoria, Australia
Ian Online content
Ian  Online Content
Victoria, Australia
i ran the same headers with j heads on my indys -1 ans -2 s just needed a tickle up at the flange end
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661161
08/22/14 10:17 AM
08/22/14 10:17 AM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
Who makes those gaskets with the dual bolt pattern? That set looks like they will work for me. I have econo W2's on my 408 in my d100. So no one makes a W2 header for that combo and I have to use standard headers. Always have trouble with them leaking.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Page 2 of 3 1 2 3
