Re: Oil Pump Driveshaft Wear
[Re: GTX MATT]
#1660717
08/20/14 07:40 PM
08/20/14 07:40 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Gotcha! I will be buying one now. Who sells them?
Any chance this is common with the MSD Pro Billets?
As far as who sells them, I got it when I worked at a fastener distirbutor but you should se able to find them at Granger or Fastenall or any hardware store. I believe it's 1/2" shaft diameter, measure yours to be sure, it was many years ago when I did this.
[Re: Bigcube]
#1660718
08/20/14 07:45 PM
08/20/14 07:45 PM
Posts: 5,167 CT
GTX MATT
CT
Gotcha, what will they call it at the hardware store?
[Re: Bigcube]
#1660721
08/21/14 12:49 PM
08/21/14 12:49 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Big Cube very good pics of that issue! I will check that. Although my gear engagement is in the middle like a ring & pinion. Thanks, Don
[Re: scatpacktom]
#1660727
08/22/14 06:09 PM
08/22/14 06:09 PM
Posts: 427 Sweden
Mopar Guy
Sweden
That is what they do when the bushing in the block is bad. Is there excessive clearance between the shaft and the bushing?
I have also askt about that in this subjekt if you reed my posts like a qestion if the bushing or shaft have mutch wear ! But then it must be pretty mutch to get that pattern as the shaft then will be forceŽd out of center It could be ofcorse !
