Page 2 of 3 1 2 3
Re: 1939 Dodge coupe [Re: Mopar Ron] #1660132
08/23/14 08:51 PM
08/23/14 08:51 PM
Western Pa
farmboy70 Offline OP
Western Pa
Would a early Dakota frame be a good choice?
Re: 1939 Dodge coupe [Re: farmboy70] #1660133
08/24/14 12:19 AM
08/24/14 12:19 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
If a car is as wide as a 39 truck it will but wheels are very limited and ride height cannot be very low. If it was my project I would go mustang II since it easy to do.
Re: 1939 Dodge coupe [Re: moparpollack] #1660134
08/24/14 01:16 AM
08/24/14 01:16 AM
Western Pa
Western Pa
Who would be a good vender for a Mustang front suspension kit?
Re: 1939 Dodge coupe [Re: farmboy70] #1660135
08/24/14 03:17 AM
08/24/14 03:17 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Fat man fabrication makes a front stub but there site is kind of hard to find stuff on
what I found was a stub for around $1,100.00 which I feel is a bit high.
I do most of my own work and I put 2 rails out the front and use a mustang II cross member or one from ebay
on my Race truck I have a stock mustang cradle that I cut out of a 1976ish mustang and trimmed down and fitted it to a 80's toyota PU frame rails.
you can get after market cross members on ebay but you will still need some kind of frame rails sticking out front to hook it to.
you might want to check out measurements of a stock Dakota chassis and see how wide they are, just remember the stock wheel are inboarded quite a bit.
here is the thread on my truck
https://board.moparts.org/ubbthreads/show...e=3&fpart=1
so with all that being said I sure don't know what would be the best way to go with your car.
it would all depend on how you feel about fabrication work and how much of it you can do..
Re: 1939 Dodge coupe [Re: farmboy70] #1660136
08/24/14 03:24 AM
08/24/14 03:24 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
DAVE I pm,ed u,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1939 Dodge coupe [Re: farmboy70] #1660137
08/24/14 03:41 AM
08/24/14 03:41 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Fstfish66 and I did the disc brakes change on my 1940 plymouth coupe made a big difference looking at doing powersteering this winter and power windows and like fstfish fell free to ask anything
Do you have a link on how this is done?
I will try to get with the guy on the 37 parts cars this weekend.
No word yet this week if he is willing to part with them.
Here is a better picture of my car .
Couldn't help my self ,had to install some wheels I had in storage.
looks good
2015 cherokee
2013 R/T classic
Re: 1939 Dodge coupe [Re: farmboy70] #1660138
08/24/14 03:54 AM
08/24/14 03:54 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
on a 39/40 u have to chop off the frame at the fire wall and install a stub to install a mustang front suspension,,,these 39 40 front suspensions are just as good,, u need to convert to disc brakes and rack and pinion steering,,and move the upper shock mount to the frame,,
only drawl back is,, if your factory stuff is in need of a rebuild,,depending what you need to replace,,, both set ups will cost the same if you can do the work,,,,
2015 cherokee
2013 R/T classic
Re: 1939 Dodge coupe [Re: farmboy70] #1660139
08/24/14 05:01 PM
08/24/14 05:01 PM
Western Pa
Western Pa
Brought the 340 home today.
The engine is a 1970 with a 69 a body trans.
The owner is letting me bring it to my shop to tear down and inspect before I buy it.
I did notice that the right engine mount ear is broken.
Re: 1939 Dodge coupe [Re: farmboy70] #1660140
08/24/14 05:02 PM
08/24/14 05:02 PM
Western Pa
Western Pa
Re: 1939 Dodge coupe [Re: farmboy70] #1660141
08/25/14 02:29 AM
08/25/14 02:29 AM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Can I get a vin check on the engine and trans?My 70 swinger is missing its original 340 and 4 spd.
Probably a long shot.
Tom
Re: 1939 Dodge coupe [Re: crowbait] #1660142
08/25/14 09:33 AM
08/25/14 09:33 AM
Western Pa
Western Pa
Hi Tom
No problem, I will get it cleaned up today and get back to you.
I was thinking I should post the numbers in the lost and found section also.
I am not married to the idea of the 340 and if it would connect to the original car that would be good also.
Re: 1939 Dodge coupe [Re: farmboy70] #1660143
08/25/14 11:23 AM
08/25/14 11:23 AM
Western Pa
Western Pa
Here are the numbers.
Engine 0b251871
Trans LM23P9B133634
Trans number's are very lite and difficult to read.
That is my best guess at this time.
Re: 1939 Dodge coupe [Re: farmboy70] #1660144
08/25/14 11:39 PM
08/25/14 11:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So, do you have pictures of the 37?
The last 39 Plymouth I had, I did the disc brake conversion and the Caviler rack & pinion. I didn't get around to doing the upper shock relocate before someone needed the car much more then I did (I had to put a motor in my work truck at that time). I also did a 39 with a Dakota front clip, but I didn't get that one done either, before it went down the road (I'm seeing a growing pattern here. )
I have, however completed a Dakota swap on a 48 Plymouth, and my current car has the full Dakota frame under it.
The wheels on a Dakota (87-90 are 5 bolt wheels, 91-96 can have the 6 bolt wheels changed to 5 bolt by just swapping the 5 bolt parts, swapping to 5 bolt wheels on the 97 & newer is not an easy task) are factory inset by about 2" compared to the old style wheels, and I believe the Dakota has a 60" track. That puts the stock offset Dakota wheels close to the fender edge. If you intend on slamming it to the ground, I suspect the tires will rub the fenders, or be very close. At normal ride height, everything should be OK.
With the Dakota, just like any time you change the frame, you will need to fabricate a radiator support for your 39.
Between the Dakota and the upgraded original frame, if your original frame and suspension is in good condition, its tough to beat the original frame, and I suspect the final cost is going to be about the same money spent. To do it right, any way you go, should have new brakes, rebuilt suspension, new shocks, and rebuilt steering box/rack.
I've not ever done a Mustang II front end, and the money spent is about the same. Gene
Re: 1939 Dodge coupe [Re: poorboy] #1660145
08/26/14 12:37 AM
08/26/14 12:37 AM
Western Pa
Western Pa
Hi
I talked to the owner of the cars and we set a price depending on the condition of the 340.
I took it apart tonight and it is in bad shape.
Badly rusted cylinder walls and bad pistons.
I will be talking to him soon about redoing the pricing of the cars and engine.
He has three 1988 gmc trucks, one caravan, and the two 37's and a 50's chevy truck in the deal with the 340 and trans.
If I purchase any or all of these I will post pictures.
I am leaning to the Mustang parts as of now.
Once I get the body off the frame I will have a better idea of what I have to work with.
The frame on my car looks good but a better inspection with the body off will help me decide.
Probably try to reach him tomorrow.
Re: 1939 Dodge coupe [Re: farmboy70] #1660146
08/28/14 12:58 AM
08/28/14 12:58 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looks like you will have to use a motor plate to mount the 340
2015 cherokee
2013 R/T classic
Re: 1939 Dodge coupe [Re: fstfish66] #1660147
08/29/14 11:59 PM
08/29/14 11:59 PM
Western Pa
Western Pa
Here are a few pictures of the parts cars. I made a offer on the lot today and the owner wants to think about it and will get back to me soon .
Re: 1939 Dodge coupe [Re: farmboy70] #1660148
09/02/14 12:27 AM
09/02/14 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'd love to have that coupe body (the one on the left in the 1st picture) if the price is right. Gene
Re: 1939 Dodge coupe [Re: farmboy70] #1660149
09/02/14 12:28 AM
09/02/14 12:28 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wow the coupe looks like a 37/38...shame to let it rot
2015 cherokee
2013 R/T classic
Re: 1939 Dodge coupe [Re: fstfish66] #1660150
09/06/14 01:44 PM
09/06/14 01:44 PM
Western Pa
Western Pa
Hi
Still no word on the cars ,I will try to see him today.
We got the body off the frame this week.
Frame looks good overall.
Re: 1939 Dodge coupe [Re: farmboy70] #1660151
09/06/14 03:54 PM
09/06/14 03:54 PM
85086
Lil Herman
Lil Herman
85086
Hi
Taking your time on this one!
Page 2 of 3 1 2 3
