Re: fuel return line install
[Re: pittsburghracer]
#1658314
08/13/14 04:03 PM
08/13/14 04:03 PM
Posts: 7,506 Az
Crizila
Az
I removed my foam years ago because of the alcohol in pump gas with zero issues. These are the instruction that came with my BG400 pump.
Bypass The return line should be fed with a single #8 or 1/2" line. Plumbing kit number 150187 is avail- able for this application. The return should expel the bypassed fuel into the liquid rather than into the air space of the fuel cell. This will prevent aeration of the fuel. All fuel tanks and cells should have fuel cell foam installed to prevent fuel slosh. WARNING: DO NOT BLOCK THE RE- TURN, VENT, OR PUMP FEED. MAKE SURE THAT THE SYSTEM IS LEAK FREE AT ALL CONNECTIONS...YOUR SAFETY DEPENDS ON IT! Wiring BEFORE MAKING ELECTRICAL CON- NECTIONS, DISCONNECT THE POSITIVE TERMINAL FROM THE BATTERY. Your BG400 Fuel system should be connected to a fully charged 12 or 16 volt battery. A fuel pump, like any other electrical accessory, will only perform at its best when given adequate voltage. The black wire is a ground (-) and the remaining wire is a switched hot lead from a 12 or 16 volt source. If wired incorrectly, the pump wi
Interesting? They don't tell you how long this line in to the fuel should be. Why not just plumb the return line in to the bottom of the tank if you are that concerned about fuel aeration?? That would cover all scenario's. JMO, but I aint buyin it.
I think the reason they want it up high is to prevent any chance of suction. Kinda like priming a pump.
"Any chance" means it can't be submerged in the fuel - I would think? Still doesn't answer how long the tube should be. My return line at idle dumps like a garden hose. The fuel still has to go through the foam, lines, and pre-filter before it goes in to the pump. If it still has air in it, God bless it! A bigger concern to me would be return ine back pressure / tank vent size.
Fastest 300
[Re: sixpackgut]
#1658315
08/13/14 04:04 PM
08/13/14 04:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know sometimes I'm a bit out in left field, but I have thought about this before. like in a fish tank where water flows out of the filter and dumps into the water, its adding oxygen to the water, is it possible that when fuel is dumping into a fuel cell, is it adding oxygen to the fuel similar to some race fuels that are oxygenated
If it is , its so minute you wouldnt ever see any affect.. I did a study on this at Chrysler and I found that if it enters below its a lot less issue with air.. thats the reason we STILL return it well below the fuel level... now we use the return to accumulate more fuel in our reservoir that surrounds the pump... injected engines HATE air(as in bubbles)... a ton of air is induced at the carb when the fuel goes past the N/S into the bowls
[Re: MR_P_BODY]
#1658316
08/13/14 04:14 PM
08/13/14 04:14 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
FWIW Aeromotive's Fuel cell w/ the in-tank A1000 pump...returned below fuel level. I will be borrowing this idea with the cell I am building this winter for the car.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: sixpackgut]
#1658317
08/13/14 04:28 PM
08/13/14 04:28 PM
Thumperdart
State of confusion
Whatcha smokin there 6.................. But it actually makes sense for some crazy reason.
Except for the fact that the pump doesn`t wanna suck bubbles but solid fuel.............
