Re: gtx trunk finish panel
[Re: NachoRT74]
#1658187
08/12/14 10:05 PM
08/12/14 10:05 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
What year GTX do you have?
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#1658188
08/13/14 09:26 AM
08/13/14 09:26 AM
btomasko
[Re: btomasko]
#1658189
08/13/14 03:09 PM
08/13/14 03:09 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
If the broken ones are on the end edges of the panel, which mine were, I ended up drilling into the metal, using a bottoming tap to start SOME threads, then used 3/4" long pieces of threaded rod (with JB weld) screwed into the panel and left to set. Might sound a little mickey-mouse, but it works. You just have to be careful not to drill all the way thru the panel where the broken studs are. My panel cinched up tight to the trunk lid and has been like that for 3 years now. ![](/ubbthreads/images/graemlins/thumbs.gif)
