Re: Alterkation drag only setup
[Re: bigtimeauto]
#1657872
08/12/14 07:00 PM
08/12/14 07:00 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
My Alterkation has 3.5" of travel, Bob's has 6" with more available by trimming the upper control arm stops. Again I'm not bad mouthing either or saying one is better. I have photos of both cars with the frontend in the air and I aligned both cars. Neither have any kind of bump steer issues.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: J_BODY]
#1657877
08/12/14 11:22 PM
08/12/14 11:22 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Jay,what rate front springs are you currently running?
I have been told by Calvert and few superstock racers, you need 5 inches of travel to get them to work. Like I stated to bigtime I haven't tried tying the front end down to see if less travel works. Now Ron Rhoades in his x275 camaro doesn't have the travel my front end does and he hooks fine with calverts. But he has a ton more power then I do. So I do know what you have to do to make a car work changes at different power levels.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: bigtimeauto]
#1657883
08/13/14 12:33 AM
08/13/14 12:33 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
bigtime, your front tires are nicely tucked under the front fenders for an alterkation, shorter control arms???
yes I took .750 out of them. I think bill will do it also if you ask when you order it.
Didn't know that was an option but everybody should do this.
[Re: J_BODY]
#1657885
08/13/14 12:37 AM
08/13/14 12:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
...and I agree. The rack does not turn as sharp as the stock steering. I'll worry about that when i have to parallel park in the staging lanes.
Can you shorten the steering arm 1".. that would help the degrees of turn.. thats what I did on my struts
[Re: 1967dartgt]
#1657887
08/13/14 12:43 AM
08/13/14 12:43 AM
MR_P_BODY
You need to take .750 out of the rack also.
Your not moving the inner pivot point so no reason to change the rack
