Re: Weird vibration just backing off throttle
[Re: Challenger 1]
#1657359
08/14/14 06:25 AM
08/14/14 06:25 AM
Posts: 885 alberta
Publicbottle
alberta
Yes this is beginning to make sense. Thank you very much for helping with this! So just for the record....these old mopars are typically a trans "up" and rear pinion "down" configuration? Would it be worth trying to get my trans output angle to be in the positive?? ( up? )
[Re: dart4forte]
#1657361
08/14/14 12:03 PM
08/14/14 12:03 PM
RapidRobert
If the front yoke/shaft interface angle is a "V" then you want the pinion/shaft interface angle on the other end to be a "^" (an upside down "V" and you want several degrees of angle on each end & the angles to be equal. The factory angles you have in place will dictate which "V" is up and which "V" is down. You just dont want either/both ends in a perfect straight line and you dont want too much angle but you do need some angle (several degrees) plus you need a bit more downward drop on the pinion cuz it rises (how much I ain't sure/check on that/depends on your app, drag/street etc). A record setting drag racer might want a straight line for the nth degree of no horsepower loss (angles cost power however slight) but for everyone else a slight angle is needed as ujoints will wear excessively if the angle is dead on straight (you'd think it'd be the opposite but it ain't), something about the needle bearings need to circulate/move iirc ??
[Re: dart4forte]
#1657362
08/14/14 12:19 PM
08/14/14 12:19 PM
Challenger 1
Cincinnati, Ohio
Do you have the Mopar chassis book?
I know you weren't talking to me, but yes I do. And I have read the crap out of it over the years, long before I was a drag racer.
[Re: savoy64]
#1657366
08/20/14 03:11 AM
08/20/14 03:11 AM
Posts: 885 alberta
Publicbottle
alberta
Would just like to post a resolve to my issue. I know I hate reading through a post only to find no solution in the end. Hoping that someone else can learn from my mistakes, I find this a bit embarassing, but glad I got it figured out, a HUGE thanks to Dr. Diff! A great guy and wealth of knowledge!!! Turns out I installed my 3 degree shim in backwards and ended up with over 10 degree negative pinion angle. By reversing the shim (thin end forward) I changed my angle 6 degrees yielding me with a 4.5ish negative pinion angle. Test drive went great and immediately it felt smoother! Thanks everyone!!
[Re: Publicbottle]
#1657367
08/20/14 08:42 AM
08/20/14 08:42 AM
Challenger 1
Cincinnati, Ohio
Cool deal, IMO the shims should only be left in there for a short time. They make for weak rear end because they will corroad and fall out. Then you have a bigger problem. Get the saddles on the rear end re-welded where there supposed to be.
