Re: ECUs, all the same?
[Re: Challenger 1]
#1656983
08/13/14 10:09 AM
08/13/14 10:09 AM
RapidRobert
I agree with Challenger & I'm in a minority here but I consider the ECU just a (coil) primary current on/off switch & as long as it ain't pulling timing like the newer orange boxes reportedly do (I never plotted a timing curve chart) that a good made in USA one is fine & the real power is in the coil/ballast (or no ballast) combo. The standard motor products LX101 was a good standby tho I bought one the other day & it is made in china now (ran OK & turned out the prob was my black FBO coil was what had died)
[Re: feeeighteefee]
#1656985
08/14/14 03:16 AM
08/14/14 03:16 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
always have a good ground also..
Yes...
On bare steel...
[Re: feeeighteefee]
#1656986
08/14/14 09:45 AM
08/14/14 09:45 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
usually heat is the culprit
and why, in most cases, is that? has nothing to do with your 'expert' buddy who told you 'ya don't need that ballast resistor. it's just holding you back'......
