Re: ECUs, all the same? [Re: Challenger 1] #1656983
08/13/14 11:09 AM
08/13/14 11:09 AM
I agree with Challenger & I'm in a minority here but I consider the ECU just a (coil) primary current on/off switch & as long as it ain't pulling timing like the newer orange boxes reportedly do (I never plotted a timing curve chart) that a good made in USA one is fine & the real power is in the coil/ballast (or no ballast) combo. The standard motor products LX101 was a good standby tho I bought one the other day & it is made in china now (ran OK & turned out the prob was my black FBO coil was what had died)
Re: ECUs, all the same? [Re: jeff968] #1656984
08/14/14 03:10 AM
08/14/14 03:10 AM
northwest49
feeeighteefee Offline
northwest49
usually heat is the culprit,take your non working one and hog out the clear insulation in the back.usually its a bad capacitor.unsolder and take to radio shack or electronic parts place and get another capacitor.usually under a few bucks.solder it back and silicone the back side and problem fixed.do it yourself and save money.bad capacitors usually bloat up or leak so its easy to tell after you remove insulation goop.always have a good ground also..
Re: ECUs, all the same? [Re: feeeighteefee] #1656985
08/14/14 04:16 AM
08/14/14 04:16 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
On bare steel...
Re: ECUs, all the same? [Re: feeeighteefee] #1656986
08/14/14 10:45 AM
08/14/14 10:45 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and why, in most cases, is that? has nothing to do with your 'expert' buddy who told you 'ya don't need that ballast resistor. it's just holding you back'......
Re: ECUs, all the same? [Re: mikemee1331] #1656987
08/14/14 11:29 AM
08/14/14 11:29 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I have had a theory ( just a theory )...bad charging issues is the most culprit. Low charge at iddle makes overheat circuit when requesting for load.
Re: ECUs, NOT all the same? [Re: jeff968] #1656988
08/23/14 12:00 PM
08/23/14 12:00 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Orange / Chrome / Gold ECU deal....
Up until approx. 10 years ago, Chrysler made these in-house in Huntsville, Al (Think: Guided missiles...Apollo Moon missions....).
Nowadays: All vendor-supplied from who-knows-where.
Rick
