Re: Synthetic tranny leakage--833 4 speed?
[Re: LAR_414]
#165641
12/11/08 12:15 PM
12/11/08 12:15 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The Pennzoil Syncromesh meets the same GM spec as the GM Syncromesh HPmike posted but cheaper.
I've used the Passon gear lube and it works well too.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: Pacnorthcuda]
#165644
12/11/08 05:03 PM
12/11/08 05:03 PM
Posts: 4,978 VA
DAMOPARS
VA
I had a similar experience and switched back. No more leaks!
Thanks for the straightforward response! I will look for a GL-4 80-90 or 75-90 dino lube. Leaks suck
Good old Dino lube Why mess with the other crap. Unless you like it in your driveway.
[Re: CJK440]
#165645
12/14/08 12:59 AM
12/14/08 12:59 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Forgot the details, but as something to do with sliders need friction to operate.
Correct! That’s why some properly formulated gear lubes come complete with friction modifiers.
Remember that not all lubricants are created equal.
If one specific synthetic lubricant falls short, does this automatically mean that all synthetic lubricants fall short?
Similarly, if a Mopar is what you desire, you don’t buy an Oldsmobile do you? No! Because even though they are both automobiles, there are some design differences that makes one more preferable in some applications over the other.
Besides, how many 60s and 70s Mopar muscle cars have you seen that are 100% leak free? It would seem that no matter how careful and attentive one is when it comes to installing new gaskets and seals, leaks can often develop regardless.
And if one uses a synthetic lubricant with a preconceived notion brought forth by urban myth that synthetic lubricants cause leaks and a leak occurs, then that obviously means that all synthetics lubricants are bad and nobody benefits from them. Or is it that a leak was going to develop anyway whether it was with conventional or synthetic?
If a gear lube is designated as an SAE viscosity and API GL-5, GL-4 specifications, whether conventional or synthetic, it shouldn’t be that far out of spec to cause detrimental effects when one is compared with the other. But then again, not all are created equal.
CompSyn
[Re: CompSyn]
#165646
12/14/08 03:42 PM
12/14/08 03:42 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most leaks that occur after changing to synthetic are due to the change, not what it's changed to. If aged dino were replaced with fresh dino lube the leak could just as easily occur. I've successfully used synthetics that were formulated for synchro in older T-10's and 833's with vast improvement in shifting; especially when cold.
[Re: John_Kunkel]
#165648
12/15/08 03:05 AM
12/15/08 03:05 AM
Posts: 166 Los Altos Hills, CA
Dans 68
Los Altos Hills, CA
John, what synthetics do you recommend?
Dan
[Re: Pacnorthcuda]
#165652
12/15/08 04:48 PM
12/15/08 04:48 PM
You didn't say where it was leaking. I use MT-90 with no issues at all. Runs great. There are a few things to keep in mind, when you re-build an A-833 tho. #1 Most of the newer brass synchro rings have six oil slots on the inside. The original Mopar ones had three. If you are using the newer ones, you may have trouble. Those oil slots throw off too much oil on your gear races, plus they are weaker than the original 3 slot synchros. That is the first issue I see as a potential problem. #2 Leaks can occur on the side cover shift lever seals. I had Liberty Transmissions modify mine with positive oil seals (no leaks). #3 Run a thin strip of high temp silicone sealant on all case gaskets (both sides), to ensure they don't leak. #4 Alway's replace your reverse switch gasket...it will leak if old. #5 Check your tailshaft vent to ensure it is not stuck shut. If stuck, it will cause excessive pressure in the case, and possible leaks. Same vent is found on a 8 3/4" axle.
