Page 40 of 47 1 2 38 39 40 41 42 46 47
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16582
06/26/06 09:21 PM
06/26/06 09:21 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Getting the wheels is a second priority right now as it will be a wheel and tire purchase as im thinking of changing the tire size to fill the wheel well more. So i will still have to hold off for now.
Getting the truck running is the first priority, and for that, i will spend the money on.
Oh, and the wheels the mrs. and i picked out ar American AR-23.
Im thinking 7's for the front with either a 225/75/15 or 235/70/15 and then 8's for the back with a 31x10.5/15. That should really fill thewheel wells and provide a nice ride while looking meaty.
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16583
06/27/06 10:04 PM
06/27/06 10:04 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
not a bad looking wheel, tire choice for the rear seems a bit big to me but what do i know ? im out in left field with the black wheels and just about any size tire i can get my hands on for free since they dont usually last more than a week before they cough up steel belts
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16584
06/28/06 02:55 AM
06/28/06 02:55 AM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
Depends on gears, all my RCs came with 3:55's and the stock recomended tire is a 235/75/15 which is a 28.5"-29.3" tall tire depending on manufacturer.
I personally would go with a wider rim/tire combo on the rear
I am running 17x9.5's with 4.5" of backspacing and 275x55x17's
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.)
1976 D100 lowered 3" & 5" Now with a 440!!! (sold)
On the hunt for another beauty to build.
Re: why isn' there much written about 81to 90 2wd truck [Re: 3XCHARM] #16585
06/28/06 03:58 PM
06/28/06 03:58 PM
The problem is sticking with a 15" wheel is that radials dont really get much wider. Plus, the 31x10.5 is 30.5" tall and will fill up the rear wheel well really good seeing that is 32" wide. And i dont want to go to wide--i dont want them sticking out, because it will be lowered to the point the the top of the tire will just be covered by the fenders. These were my reasons for the tires picked and the wheel sizes i picked. I want to stay with 15's as the prices are really good to do the entire package of wheels and tires (under $1000)
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16586
06/28/06 06:13 PM
06/28/06 06:13 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
32" wide? A 31x10.5 should be a 10.5 wide tread.
I understand wanting to keep the tire prices down, my tire package for my truck runs 700-900 dollars just for the tires.
Juat so you know, if you go to this website: http://www.tirerack.com/tires/SearchTires.jsp
and look for tires by size, when the tires come up it gives you all specs for that tire, including diameter, suggested rim width, mounted tread width, etc. check it out.
For example, a 265/75/15 is about the same size and in some cases (manufacturer) is under $100.
http://www.tirerack.com/tires/Compare1.j...amp;RunFlat=All
It is a great place to double check tire sizes since a lot of local places dont have, or dont know this info.
Re: why isn' there much written about 81to 90 2wd truck [Re: 3XCHARM] #16587
06/28/06 09:06 PM
06/28/06 09:06 PM
Opps, i just assumed to much when i was typing. The wheel opening in the rear is 32" across, the 31x10.5 is 30.5" in diameter---thus it should fill up the space when viewed from the side. I didnt meant 32" wide---sorry about that.
Yes, tire rack is a great site, i prefer the catalogs i collected from various mfg's when i worked for a dodge dealer for 12 years. I always got into the specs for stuff and scavenged up various catalogs with info and specs on a number of things---its a sickness i tell you, and im going to be sorry when i have to move---all that paper weighs alot!!!
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16588
06/29/06 01:15 AM
06/29/06 01:15 AM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
LOL I know what you mean about catalogs (kinda a specs guy myself), I did stereos for 12 years, and suspensions for 5 and still do it on the side, I still have the very first Truckin' magazine I bought in 1986!
It is true, all that paper sure gets heavy quickly!
Hmmm...... you worked at a Dodge Dealer for 12 years huh? you must have a lot of catalogs
Re: why isn' there much written about 81to 90 2wd truck [Re: 3XCHARM] #16589
06/29/06 08:18 AM
06/29/06 08:18 AM
Yes, i do and did have alot of stuff. Unfortunatly, some of it got discarded, and i really need to gather what i have left into one spot. My most useful ones seem to be the walker exhaust books and tire catalogs. I wish i was into trucks before i left the dealer, i could have gotten parts books as they had all the old ones and i was the only one willing to look up old stuff. Unfortunatly i was into cars at that time so almost everything i have deals with cars. I did get truck catalogs on CD from the ramcharger site though.....
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16590
06/29/06 10:26 PM
06/29/06 10:26 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I'm Baaaaack!
Com has been messed up, missed y'all!
I haven't had much free time tho, But nonetheless had time tonite to get on here a bit...
On the solid mount thing, my experience is mostly with tube frame buggies, and V W beetles with ford engines in em....they buzz bigtime at 6000 rpm!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16591
07/02/06 08:07 PM
07/02/06 08:07 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
im back too, went to AZ for a week man is it hot there!
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16592
07/03/06 08:04 AM
07/03/06 08:04 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
im sitting here thinking maybe just converting to 5x4.5" for easier future availability on wheels (the ones i want come in either pattern)-----what would you guys do?
The fronts are easy, just switch to earlier rotors. On the rear I switched my 87 to an early 8 3/4. Same backing plate and new drums.
I used the same driveshaft.
15 x 8's on all four.
Re: why isn' there much written about 81to 90 2wd truck [Re: Magnum] #16593
07/04/06 01:16 PM
07/04/06 01:16 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
so what would be the benifit of switching?
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16594
07/04/06 02:08 PM
07/04/06 02:08 PM
Only benifit i can see is more selection on wheels. But seeing that i have settled on something (i think) there isno advantage in my case---i was just thinking of future swaps.
I went to make my new taylor plug wires--but they sent 2 bags of HEI terminals instead of a bag of each style. I called them yesterday and they are sending out the right ones.
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16595
07/04/06 06:00 PM
07/04/06 06:00 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
I thought that only happened to me , wrong parts on a consistant basis
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16596
07/05/06 07:19 PM
07/05/06 07:19 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
has anyone ever used white face gauge overlays? how hard are they to put on?, do they suck or are they ok?
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16597
07/05/06 07:47 PM
07/05/06 07:47 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
There is a How-to article on the RCC site where a guy made his own overlays on his computer with photopaper. I haven't tried his procedure but it looked possible. I would like white face gauges myself, but I'm going with a different setup...Autometer!
Re: why isn' there much written about 81to 90 2wd truck [Re: dodgeram440] #16598
07/05/06 07:51 PM
07/05/06 07:51 PM
First thing i thought of when i saw the dash of the '85 we bought was that some autometer gauges would fit right in those holes.......
I may have to try that sometime
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16599
07/05/06 09:13 PM
07/05/06 09:13 PM
Beebe, AR
83Ram4spd Offline
83Ram4spd  Offline
Beebe, AR
It's on my "to do" list
Speed kills.......Drive a Ford and live forever!!!!
Re: why isn' there much written about 81to 90 2wd truck [Re: 83Ram4spd] #16600
07/05/06 09:49 PM
07/05/06 09:49 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Actually, I've already done the trial fit. I have the dash panel off the truck for other reasons, and I have a 5" tach...so putting 2 and 2 together...it fits,but the whole is just a hair big and I'm not sure yet how to mount it tight. I might just have to make a complete custom dash.
Re: why isn' there much written about 81to 90 2wd truck [Re: dodgeram440] #16601
07/07/06 06:41 PM
07/07/06 06:41 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
thats a great Idea but it doesnt fit into my budget, im trying to get overlays on ebay but I seem to be encountering shipping problems
