Re: B 400 solid roller
[Re: gregsdart]
#1653255
07/31/14 08:28 PM
07/31/14 08:28 PM
Posts: 914 tn
robnbird
tn
plane intake. 3500+ stall in 440, 3800 in 383. .026 .028 3500 to 6300 23-705-9 5 Three-Bolt 283R-8 283 291 252 263 .660 .660 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Best all around bracket or Super Street cam. Best in light to medium weight car with 11:1 compression, 4200+ stall in 440, 4500+ stall in 383. .026 .028 4000 to 6500 23-706-9 5 Three-Bolt RX296R-8 296 303 263 270 .650 .651 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − 383 Super Gas, Super Street, 12:1+ compression, 5000+ stall. .028 .030 4000 to 7000 23-758-9 5 Three-Bolt 306BR-8 306 306 273 273 .625 .625 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Good Super Gas, Super Street with 12:1 compression and 850+ CFM carb. 5000+ stall with 440, 5400+ with 383. .026 .028 4500 to 7000 23-707-9 5 Three-Bolt RX308R-8 308 315 275 282 .657 .659 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Quick 16, Super Comp for medium to large cubic inch. .026 .028 5500 to 7800 23-704-9 5 Three-Bolt REV315R-6 315 321 282 288 .693 .665 106° 829-16 3125 3125KT 1071-KIT 23 1073-KIT 23 N/A 947-16 2 26082-16 2 739-16 722-16 627-16 26 612-16 512-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Fast Bracket, Super Gas or Super Comp. Best with 12.5:1 compression and ported iron or aftermarket heads. 5500+ stall in 440. .026 .028 4800 to 7200 23-708-9 5 Three-Bolt RX316R-8 316 321 283 288 .660 .663 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Super Gas, Super Comp, Fast Brackets. 5000+ stall. .028 .030 5000 to 7200 23-732-9 5 Three-Bolt 320TR-8 320 320 288 288 .692 .692 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Super Quick, Super Gas, Su- per Comp or Fast Brackets. For use in medium to large engines with aftermarket heads. 12.5:1 compression with 5500-6000 stall. .026 .028 5500 to 7500 23-709-9 5 Three-Bolt RX322R-10 318 330 285 292 .705 .705 110° 829-16 3125 3125KT 1071-KIT 23 1073-KIT 23 N/A 947-16 2 26082-16 2 739-16 722-16 627-16 26 612-16 512-16 2 622-16 N/A 424 N/A MeCHaNICal ROlleR − Super Gas, Super Street, 12:1 compression, 5000+ stall, 5.13 gear. .028 .030 5000 to 7200 23-770-9 5 Three-Bolt 323BR-8 323 323 289 289 .690 .690 108° 829-16 3125 3125KT 1071-KIT 23 N/A 943-16 2 731-16 627-16 26 505-16 2 622-16 N/A 424 N/A 2 Requires machining on cylinder heads 5 Requires distributor gear upgrade 7
[Re: robnbird]
#1653256
07/31/14 08:41 PM
07/31/14 08:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Greg thanks .. What would your numbers be for a 650 to a 670 lift .
I have learned that if you max flow at .650 lift that you would like about .750 lift on the cam(at the valve) because your at the .650 lift a much longer time (you pass the .650 lift point 2 times and all the time between) for better filling specially at RPM when you have a shorter time period to fill... also the .750 would be a decent starting point or higher ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1653258
07/31/14 11:29 PM
07/31/14 11:29 PM
Posts: 914 tn
robnbird
tn
what do you think about the last 4 of these comp cams? thanks
[Re: robnbird]
#1653259
07/31/14 11:57 PM
07/31/14 11:57 PM
MR_P_BODY
The problem with those shelf cams is if you want the lift the duration goes up with it... if you knew the head flow and what rpm you wanted to turn would help ![](/ubbthreads/images/graemlins/wave.gif)
[Re: robnbird]
#1653260
08/01/14 12:12 AM
08/01/14 12:12 AM
Posts: 1,505 TN
SCATPACK 1
TN
I don't think you need to go more than a R-282-286 on the duration. Lift will be determined by what the heads flow and at what lift. Some engines like less lift and will actually run better with a shorter cam because of how the heads flow. What overlap or lobe separation have you decided to go with? What is the compression of the pistons you ordered.
Old Geezer Racing
[Re: MR_P_BODY]
#1653262
08/01/14 12:46 AM
08/01/14 12:46 AM
Posts: 914 tn
robnbird
tn
the air flow I have to guess now ,, but from what I have read it possible will be around 320ish
[Re: robnbird]
#1653263
08/01/14 12:58 AM
08/01/14 12:58 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
I used a Comp Cams custom grind solid roller cam in my old pump gas Duster motor, it was 260@.050 intake with .420 lobe lift, 266 @ .050 on the exhaust lobes with .409 lobe lift. 108 LSA in at 106 to 107 on the intake side ![](/ubbthreads/images/graemlins/thumbs.gif) I used a set of Harland Sharp 1.60 ratio(actually checked to be 1.65 ratio at the retainers ![](/ubbthreads/images/graemlins/thumbs.gif) ) rockers, that combination flat rocked ![](/ubbthreads/images/graemlins/thumbs.gif) . My message is sometimes more duration is not the answer, more lift on BB Mopar heads does help fill the cylinders well ![](/ubbthreads/images/graemlins/scope.gif) Camshaft picking is a art, just like converters can be ![](/ubbthreads/images/graemlins/shruggy.gif) On your deal I would look at a cam with 268 to 274 @ .050 on the intake side and 274 to 278 @ .050 on the exhaust side with as much lobe lift I could get on both lobes, ground on a 108 or 110 LSA and install it to start with from 104 to 106 on the intake side ![](/ubbthreads/images/graemlins/thumbs.gif) :twocents :Make sure and get the best valve springs and pushrods out there ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: robnbird]
#1653264
08/01/14 01:00 AM
08/01/14 01:00 AM
MR_P_BODY
At what lift... that'll say how much lift you need if you want to go all out ![](/ubbthreads/images/graemlins/wave.gif)
[Re: robnbird]
#1653265
08/01/14 10:01 PM
08/01/14 10:01 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[qu:
I think they are way to big for your combo. ![](/ubbthreads/images/graemlins/thumbs.gif)
Bigger isnt always faster. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Sport440]
#1653266
08/02/14 01:21 AM
08/02/14 01:21 AM
Posts: 914 tn
robnbird
tn
[qu:
well OK I don't have the heads ported as yet but will before long and then I will post that and get opinions .. thanks for the help ... I have decided to get a indy 400-3 intake . I would like to find a used one some where .
[Re: robnbird]
#1653267
08/02/14 01:45 AM
08/02/14 01:45 AM
Sport440
Canton, Ohio
[qu:
Well, okay here too. Nice car by the way, okay Super nice car by the way. Your 6.00,s shouldnt be to hard to achieve with what your working with. Do you have any latest pics of the car? Seen the pics before and it is a sweet ride. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Sport440]
#1653268
08/02/14 02:39 PM
08/02/14 02:39 PM
Posts: 914 tn
robnbird
tn
[qu:
try this
