Re: Floats for a Carter AVS? [Re: 62maxwgn] #165263
12/11/08 01:29 AM
12/11/08 01:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The size of the float makes no difference as long as the level is correct.The difference is in the tang that contacts the needle/seat housing.Bottom is AVS,top two AFB.
I think I have some of those AFB types in my AVS. I can get the right float height numbers, closed and droop.
Re: Floats for a Carter AVS? [Re: autoxcuda] #165264
12/11/08 10:20 AM
12/11/08 10:20 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
To learn about that carb I'd start by getting a book such as the following:
http://www.mre-books.com/sa130/sa130_2.html
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165265
12/11/08 10:22 AM
12/11/08 10:22 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Oh, and is the Standard part number above definitely the correct one?
If the info is coming from Bill at A&M you can be sure its right.
Re: Floats for a Carter AVS? [Re: 69Cuda340S] #165266
12/11/08 02:05 PM
12/11/08 02:05 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
That carb you have is in the 600cfm range. The 300 would have had a HP 440 carb in the 725-750cfm range.
It will run good and be pretty spunky on the lower end. Upper range? It may fall on it's face. Are you racing, or just cruising?
It should MPG a little better than the bigger one.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Floats for a Carter AVS? [Re: Rug_Trucker] #165267
12/11/08 02:29 PM
12/11/08 02:29 PM
Zebulon
Stationwagonguy Offline OP
A Closet Buick Man
A Closet Buick Man
Zebulon
Currently, it's a big cruiser. I like to beat on it a bit, but it's no racecar. 727 with a shiftkit, 2.76 open rear end.
It sucks at the bottom end, does pretty well up top. It never stops winding out. I'm sure it can't do 110 MPH thanks to it's aerodynamics, but it's a lot of fun up top.
Eventually, I'll do something else, but for now I just want it to be driveable again. :shrug:
[image][/image] Bob SWG '68 Chrysler Town & Country, 'Katy Jo' '70 Chrysler 300 2-door '78 Impala 2-door
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165268
12/11/08 02:35 PM
12/11/08 02:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
/quote]
You just may be surprised!
Re: Floats for a Carter AVS? [Re: Stationwagonguy] #165269
12/11/08 02:39 PM
12/11/08 02:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
That # came right out of the standard parts manual
if you use crossover book , all bets are off.
Re: Floats for a Carter AVS? [Re: gtx6970] #165270
12/11/08 03:28 PM
12/11/08 03:28 PM
With your weight/gearing that size of carb will work fine for you. I just stopped by my parts house & they show in the standard "hygrade" brand a FL98 float for an AFB & 2 floats for AVS's an FL95 and a FL97. After reading prior posts I dont know if his book was a crossover manual or not
Re: Floats for a Carter AVS? [Re: 62maxwgn] #165271
12/11/08 04:10 PM
12/11/08 04:10 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
Haha, I know the speedo is off, but I've put is well past the marked 120 on there. Whether I was really going that fast, who knows.
Re: Floats for a Carter AVS? [Re: gtx6970] #165272
12/11/08 04:10 PM
12/11/08 04:10 PM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
Cool, thanks Bill! Gonna go look it up.
