Page 3 of 3 1 2 3
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652329
08/02/14 12:50 AM
08/02/14 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This was the other side after removing the u-bolts If I was in the left lane,woulda taken down the TREE
This is where the boxed in units come into play..
you got your $7 worth
No Mr.p ,the $7.00 ones were installed today They been "in stock" since '93. Welded them in and added some bracing
I would have welded the extra straps on at the ends
then up to the tubes.. it has a better leverage
against bending... but at least they look burnt in
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652330
08/02/14 12:52 AM
08/02/14 12:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Nice, but a little more weld please.
Re: Broken weld on spring perch??? [Re: Sport440] #1652331
08/02/14 02:36 AM
08/02/14 02:36 AM
Great Neck,LI,new york
hemi-itis Offline OP
Went to the flat part of the perch with the gusset,figured it be stronger than the edge
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 3 of 3 1 2 3
