Page 2 of 3 1 2 3
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652309
07/30/14 12:42 AM
07/30/14 12:42 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
For now I would reweld the perches you have and add some gusset plates on the ends similar to the pics of the calvert perches.
Re: Broken weld on spring perch??? [Re: Sport440] #1652310
07/30/14 01:09 AM
07/30/14 01:09 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Here's a shot of a perch gusset.
Re: Broken weld on spring perch??? [Re: PC-CHARGER] #1652311
07/30/14 01:23 AM
07/30/14 01:23 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I had a buddy draw me up and laser cut a set of these, 360* of weld around the tube.
Photobucket sucks
Re: Broken weld on spring perch??? [Re: Bad340fish] #1652312
07/30/14 01:55 AM
07/30/14 01:55 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Calvert perches $39
I just did Dizusters Dana tonight. Added gussets on the ends of the standard Mororso perches that look exactly like the Calvert style. Had The Miller 250 turned way up, welded a inch or so at a time and let it cool between.
Doug
Re: Broken weld on spring perch??? [Re: dvw] #1652313
07/30/14 07:53 AM
07/30/14 07:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you don't need all that, this is the way i do it. just go to home depot and get a piece of flat stock and form it around the tube as it is welded.
Re: Broken weld on spring perch??? [Re: Quicktree] #1652314
07/30/14 08:27 AM
07/30/14 08:27 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
All I did was add the flat stock on the ends similar to whats added on the Calvert style and welded it on.
Doug
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652315
07/30/14 09:33 AM
07/30/14 09:33 AM
australia
charger410 Offline
charger410  Offline
australia
That's what I figured Installed new rear shocks and noticed something shiney in the rust
I used to have those same perch'es on my small block charger and they ended up looking like a half moons after about 1000miles LOL. Ended up making some perch'es very similar to the Calvert's
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Broken weld on spring perch??? [Re: charger410] #1652316
07/30/14 09:48 AM
07/30/14 09:48 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Re: Broken weld on spring perch??? [Re: Copper Dart] #1652317
07/30/14 11:28 AM
07/30/14 11:28 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
A few years ago I put Caltracs on my car. The first few launches with those crushed the axle tubes and broke the spring perches. After I replaced the rear end housing I used Calverts spring perches. They are very nice...no problems ever since. Here is a pick of my new perches with the old crushed axle tubes that were getting thrown out.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Broken weld on spring perch??? [Re: Quicktree] #1652318
07/30/14 11:34 AM
07/30/14 11:34 AM
Great Neck,LI,new york
hemi-itis Offline OP
I like that!! I piece of flatstock blacksmithed into place and welded!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Broken weld on spring perch??? [Re: Quicktree] #1652319
07/30/14 11:44 AM
07/30/14 11:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
thats because all the weld is on the bracket and zero penetration on the tube
If I was to place a bet, I would agree, however we by the pic have no way to know whether the perch was prepared in the weld area with a 45 degree chamfer, not likely, but possible, and there is no visible chamfer seen in the un welded ends. The weld looks like it was maybe done in place, ie overhead stick, requiring more welding skills and probably apprehension about overheating and warping the housing?
And since the highest stressed area of this area is the weld ends, likely at one end it has the least penetration at weld start up, I unusually turn the corner and go inside the perch at the ends with the weld a bit.
No one has mentioned any warpage issues and rewelding the housing ends, after this now being the second weld up?
Re: Broken weld on spring perch??? [Re: jcc] #1652320
07/31/14 11:23 PM
07/31/14 11:23 PM
Thank you all for the pictures and advise
Brought the car over to my friends shop.He crawled under the car on my flatbed to see what he needed to do. He showed me how the other perch was twisted. Thankfully I had a set in stock and he picked up some 1/2 inch u-bolts to upgrade the smaller ones I had. I'll bring the car back in the morning.Should take a few hours to box the replacement perches and weld them in properly with some PENETRATION!!
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652321
08/01/14 11:17 PM
08/01/14 11:17 PM
The invoice taped to the box Was billed to me by Bob Koller Dodge in Naperville Il and dated 8/19/93 ,amount $7.31 for 2 perches.
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652322
08/01/14 11:45 PM
08/01/14 11:45 PM
jersey
Spaceman Spiff Offline
jersey
This just happened saturday 6,500 rpm shift on my buddy's gasser.
Almost put the car in the woods.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Broken weld on spring perch??? [Re: Spaceman Spiff] #1652323
08/02/14 12:16 AM
08/02/14 12:16 AM
Mine broke at South Mountain on Sunday of our Carlisle weekend
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652324
08/02/14 12:21 AM
08/02/14 12:21 AM
This was the other side after removing the u-bolts If I was in the left lane,woulda taken down the TREE
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652325
08/02/14 12:24 AM
08/02/14 12:24 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Did it bend the axle tube?
Re: Broken weld on spring perch??? [Re: hemi-itis] #1652326
08/02/14 12:24 AM
08/02/14 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is where the boxed in units come into play..
you got your $7 worth
Re: Broken weld on spring perch??? [Re: Clanton] #1652327
08/02/14 12:35 AM
08/02/14 12:35 AM
Luckily not,broke the weld on the rt side and twisted the left.
Re: Broken weld on spring perch??? [Re: MR_P_BODY] #1652328
08/02/14 12:40 AM
08/02/14 12:40 AM
No Mr.p ,the $7.00 ones were installed today They been "in stock" since '93. Welded them in and added some bracing
Page 2 of 3 1 2 3
