Re: Fuel mileage in 2005 Ram 2500 diesel suddenly dropped
[Re: 71yelladustr]
#1652182
07/29/14 09:20 AM
07/29/14 09:20 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
While I do agree on the fuel quality today check the engine oil level and make sure it isn't rising, an injector could be leaking into the crankcase.
[Re: RODHALL]
#1652184
07/29/14 03:08 PM
07/29/14 03:08 PM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
yes, B-20 BIO will have less BTU's in it, and less fuel mileage... make sure what you are getting at the pump.... it makes a big difference... some stations here are not labeling there pumps as B20..which is a no-no...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: az426john]
#1652185
08/01/14 02:36 PM
08/01/14 02:36 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
For sure, the easiest to try first would be a different fuel station even if you have to go out of your way to find a high turnover place.
Your air filter should be good but check it anyway and then on to a new fuel filter.
Mo' Farts
Moderated by "tbagger".
[Re: az426john]
#1652187
08/11/14 12:32 PM
08/11/14 12:32 PM
Guitar Jones
It looks like this could be the problem as the oil level is above the full mark and appears to be climbing on the dipstick. It is now about 1/4 inch below the part number stamped in the dipstick.
This started just after I rescued my neighbor and pulled his travel trailer back to Phoenix.
Is there a diagnostic check to determine if it is an injector leaking into the crankcase?
I will let you know what I find out.
I used some fluorescent dye for fuel/oil and pour it into the fuel filter canister then run the truck with the valve cover off with a black light to see which injector was leaking. Makes a bit of a mess but you can spot it pretty quickly.
[Re: J_BODY]
#1652190
08/12/14 10:21 AM
08/12/14 10:21 AM
Guitar Jones
Oh yeah, you definitely don't want to touch any wiring or anything else for that matter while the engine is running with the cover off. You could lose some fingers from high pressure fuel spray or be electrocuted from the voltage those injectors operate at.
High pressure fuel injected into a vein will kill you too.
