Re: Spark plug wire recommendation [Re: birdtracker] #1649539
07/25/14 11:42 AM
07/25/14 11:42 AM
Az
Crizila Offline
Crizila  Offline
Az
D.U.I. "live wires"
Fastest 300
Re: Spark plug wire recommendation [Re: fullmetaljacket] #1649540
07/25/14 11:52 AM
07/25/14 11:52 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
My only complaint with the firecore wires is my moroso had heat shrink sleeves over the boot and wire points and they had heat shrink cyliner markers on them. The firecore wires don't, just have the little white cylinder markers that always move and I hate them.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Spark plug wire recommendation [Re: D-50] #1649541
07/25/14 01:59 PM
07/25/14 01:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I was running the $16.00 Autozone wires for a while and changed to the expensive MSD wires and I saw no difference.
Grab a boot while running and ...........
Re: Spark plug wire recommendation [Re: justinp61] #1649542
07/25/14 02:04 PM
07/25/14 02:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have Firecores on my small block, but have a new set of Magnecors to try. My Firecores are a ton long and the boots are huge. Good wires I'm sure, just don't care for the fit.
Did you have him send a basic set cos he`ll go off of your measurements and make em perfect like mine were.
Re: Spark plug wire recommendation [Re: Thumperdart] #1649543
07/25/14 02:25 PM
07/25/14 02:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Count me solidly in the camp that believes there is virtually zero horsepower gain from one brand of wire to another... not squat...
I would be be looking at heat shielding/ability to last being around heat, fit, and even appearance if its important to what a hobbyist has going on under the hood....
Hot rod magazine in fact a few years ago dyno'ed about 10 different wires and said the same thing in an article expressedly to clarify this myth......
So... not being a politician, I will buy wires that fit and are a nice color that matches my underhood....
I find it kinda funny that a fuel team would prefer one wire over another( assuming quality brands being used) because they make way more power than can be used anyhow... thats why clutches are set up to slip so much.... all a wire has to do is conduct output from coil to plug...it isn't rocket science..... good quality wire, connectors, insulation....you are plenty good to go....anything else is politics
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Spark plug wire recommendation [Re: justinp61] #1649544
07/25/14 02:26 PM
07/25/14 02:26 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, that's an old set. One of our originals from longer than 7 years ago, looks like. Haven't used those spark plug boots in a long time. The Pro-Fit sets are longer as to route around the valve covers so guys can lash the valves without taking off the wires. Pro-Fits are for engines with headers. The wire markers moving , must be a new 7mm set. Your Magnum should have 8.5mm wires on it. Markers will not move on them.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Spark plug wire recommendation [Re: sunroofgtx] #1649545
07/25/14 02:29 PM
07/25/14 02:29 PM
slammedR/T Offline
slammedR/T  Offline
No, I sent in my old moroso and had you make me firecore50 set from them. My maggy motor is a 408 stroker with Indy heads, not stock.
Also didn't mean any thing bad just being nit picky is all, I hate those msd plastic white markers.
racemagnum
Re: Spark plug wire recommendation [Re: Thumperdart] #1649546
07/25/14 03:08 PM
07/25/14 03:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dom, I just called and ordered a set for a SBM .
Re: Spark plug wire recommendation [Re: justinp61] #1649547
07/25/14 03:10 PM
07/25/14 03:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Makes sense.......next time measure and number em and they`ll be perfect or you can shorten em and make em perfect.
