Do they make X/.001 undersized SB main bearings? #1648871
07/20/14 09:32 PM
07/20/14 09:32 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Building a 416 street/strip stroker for a buddy and when checking today using micrometer on crank and inside mics on the torqued mains I'm getting .002 and would like to have .003 so wondering if anyone makes an X or .001 340 main bearing. If not I can take it back to the machine shop and have them align hone it again and get another . 001.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Do they make X/.001 undersized SB main bearings? [Re: WadeMetzinger] #1648872
07/20/14 09:46 PM
07/20/14 09:46 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
yes clevite does Wade MS540HXK.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Do they make X/.001 undersized SB main bearings? [Re: 440W8 Duster] #1648873
07/20/14 11:26 PM
07/20/14 11:26 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I think I bought some real cheap years ago. Might still have some I will look.
Re: Do they make X/.001 undersized SB main bearings? [Re: 440W8 Duster] #1648874
07/21/14 12:02 PM
07/21/14 12:02 PM
Tulsa, Ok
Tulsa, Ok
Thanks guys!
MS540HX is the non-coated X bearings, found some for $125 and will be delivered by Thursday.
Re: Do they make X/.001 undersized SB main bearings? [Re: WadeMetzinger] #1648875
07/21/14 12:21 PM
07/21/14 12:21 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
That x bearing is a over size not under.
JAKES AUTOMOTIVE
Re: Do they make X/.001 undersized SB main bearings? [Re: JAKE68] #1648876
07/21/14 12:36 PM
07/21/14 12:36 PM
Tulsa, Ok
Tulsa, Ok
ok, maybe I stated what I needed wrong, I need .001 more clearance, so the X bearing will give me .001 more clearance. From .002 to .003.
Explanation from Clevite:
X - Bearing has .001 more oil clearance than standard
Re: Do they make X/.001 undersized SB main bearings? [Re: WadeMetzinger] #1648877
07/21/14 05:21 PM
07/21/14 05:21 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I knew what you ment I was just having some fun busting your chops!!!!
JAKES AUTOMOTIVE
Re: Do they make X/.001 undersized SB main bearings? [Re: WadeMetzinger] #1648878
07/21/14 06:43 PM
07/21/14 06:43 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yes... "X" bearing is .001" bigger. I've used them on both of my last two 360 builds to get the clearance up.
You can mix and match them with the regular bearings to dial in .0005".
Re: Do they make X/.001 undersized SB main bearings? [Re: dizuster] #1648879
07/26/14 06:39 PM
07/26/14 06:39 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Does anyone have the part# for the standard size main set? This would be for a 4" stroke crank. Jim
Re: Do they make X/.001 undersized SB main bearings? [Re: rt66jim] #1648880
07/26/14 10:15 PM
07/26/14 10:15 PM
San Antonio,TX
San Antonio,TX
MS540H
70 Duster W8 motor.
@3170 lbs.
Re: Do they make X/.001 undersized SB main bearings? [Re: 440W8 Duster] #1648881
07/26/14 11:10 PM
07/26/14 11:10 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Thanks Jim
Re: Do they make X/.001 undersized SB main bearings? [Re: rt66jim] #1648882
07/27/14 11:40 AM
07/27/14 11:40 AM
Toronto
mshred Offline
mshred  Offline
Toronto
#MS-1266 HGX were the .001" thinner main bearings I used on my 360 based build from Clevite
