Re: Wideband O2's [Re: pjc360] #1648799
07/29/14 01:07 AM
07/29/14 01:07 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would love to have one like the lm2 that stores data. I just don't know if i'll be able to afford one, hunting season is right around the corner and I need to save a little for fuel and ammunition and my rifle needs a new scope. Never ending with the spending. I will see what I can swing by the end of the summer.
If you have a laptop, the Innovate LC2 (seems to have replaced the LC1 which I use) will datalog plus run a gauge and other stuff too. MSR $189
http://www.innovatemotorsports.com/products/lc2.php
Kevin
Re: Wideband O2's [Re: pjc360] #1648800
08/01/14 02:02 PM
08/01/14 02:02 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
for the low tech guys, i've mounted my gopro camera in front of my gauge.
Re: Wideband O2's [Re: Twostick] #1648801
08/01/14 02:07 PM
08/01/14 02:07 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
Kevin
only one problem, the connector for your computer is a serial connector. better break out that windows 98 laptop
i mean come on now, really? serial connector..............please
Re: Wideband O2's [Re: joelson6] #1648802
08/01/14 02:15 PM
08/01/14 02:15 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
serial to usb adapter is cheap....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Wideband O2's [Re: HemiRick] #1648803
08/01/14 07:32 PM
08/01/14 07:32 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
serial tells me that their firmware is probably old and outdated, plus converters don't always work right.
Re: Wideband O2's [Re: joelson6] #1648804
08/10/14 06:10 PM
08/10/14 06:10 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I believe I can hook a laptop to my wide band commander to record
Re: Wideband O2's [Re: UCUDANT] #1648805
08/10/14 07:19 PM
08/10/14 07:19 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
yes you need a USB to serial adapter. They are all of $10. Wideband logging is not of much use if you cannot correlate that data to additional data such as RPM, throttle position etc... I would do the go-pro/cell vid gauge method on a carb and hopefully atleast get RPM in the picture.
however if you pull out a handheld video of your AF guage on an ODBII car, your tuner is going to hate you for it
Re: Wideband O2's [Re: joelson6] #1648806
08/10/14 09:57 PM
08/10/14 09:57 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
the first adapter I bought for $5 didn't work so I upped the price bought a $20 one from Best Buy, worked last year, this year it doesn't. looks like I'll need another one ,
Re: Wideband O2's [Re: Mr340] #1648807
08/11/14 11:21 PM
08/11/14 11:21 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
It also has provisions to hook up some tach pick up leads so the Wide band Commander should also record RPM (my car is down for upgrades currently, the wide band is just one)
