Re: Building a d150 street strip.
[Re: quickd100]
#1648432
07/28/14 07:22 PM
07/28/14 07:22 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
JeeseR, what can you tell us about the Moroso front coil springs? How did they help? better front lift? how hard was the installation? Do you remember the part# Thanks
[Re: 11secdart]
#1648433
07/28/14 08:40 PM
07/28/14 08:40 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
The moroso part number is 47180, they are listed as camaro or nova springs in the catalogs. It took me a few times to get my ride height where I wanted it but other than that pretty simple installation. Just be careful when you cut them because they are a smaller diameter material so they will be significantly longer than the stock ones. They made more difference dollar for dollar than any suspension changes I have ever made. They really help throw the weight of the heavy nose. Hope this helps, jesse
82' dodge pickup with a 499 low deck
[Re: JesseR]
#1648434
07/29/14 07:09 PM
07/29/14 07:09 PM
11secdart
new jersey usa
Thanks a lot Jesse, was it ok on the street with the springs or was it a track only set-up, Thanks Again
[Re: 11secdart]
#1648435
07/29/14 09:59 PM
07/29/14 09:59 PM
JesseR
Mountain City, TN
I drove it a lot on the street but it definitely wouldn't handle the bumpy roads as well. The front would float a little, it settled down pretty quick though.
[Re: JesseR]
#1648436
07/29/14 11:06 PM
07/29/14 11:06 PM
Posts: 162 monticello,ms
andy3965
monticello,ms
How much did you end up cutting off of the springs? I have a set of those springs we had in a Dakota, but they were cut 1 1/2 coils for them to work with the Dakota. I'd like to use them in my 75 d100 if they won't end up being too short.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
[Re: andy3965]
#1648437
07/29/14 11:41 PM
07/29/14 11:41 PM
JesseR
Mountain City, TN
I'm thinking I cut two coils off, my truck sits really low in the front though.
[Re: JesseR]
#1648438
07/30/14 12:20 AM
07/30/14 12:20 AM
andy3965
monticello,ms
Mine sets pretty low now. I have stock springs with 1 coil cut now. I think I will give the trick springs a try and see if it makes much difference.
[Re: andy3965]
#1648439
07/30/14 12:34 AM
07/30/14 12:34 AM
Posts: 2,141 junction city oregon
viperblue72
Andy is that a stock width rearend? Tubbed? Looks like a 315 drag radial? 15x8 wheel?
[Re: viperblue72]
#1648440
07/30/14 12:42 AM
07/30/14 12:42 AM
andy3965
monticello,ms
It's a 70 truck housing, stock length. I installed it on top of the leaf springs, just had to weld on new perches. It is a 315 drag radial on 15x10 wheels with 6.5in backspace. They tuck real nice!!! I did have to tub it. If you roll the wheel well lips you might can get away with less backspace and not have to tub. I already had the wheels so I just tubbed it to the frame rails.
[Re: viperblue72]
#1648442
07/30/14 11:12 AM
07/30/14 11:12 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Might want to look at replacing the lower a-arms with pocketed units from a 3/4 ton Van.....do a search in the truck forum....there's tons of info. With those a-arms you might not have to cut any coils...??? It's a pretty straight forward swap..... Here's how ours sat with the pocketed a-arms and stock height coils.... Rickster
[Re: viperblue72]
#1648445
07/30/14 10:23 PM
07/30/14 10:23 PM
rickstershemi
Unfortunately it is an 8 1/4. I know a 9 1/4 would hold up buti do not likec-clip axles. An 8.8 is alwaysa budget option too. Being a turbo Street/strip truck I don't plan on it leaving extremely hard. But probably in the high 1.5s.
8.8 Would be a good choice.....although we ran in the 8's 1/8th mile with an 8.25....still have a suregrip 8.25 sitting on the shelf....
Rickster
[Re: viperblue72]
#1648446
07/31/14 02:41 AM
07/31/14 02:41 AM
Posts: 3,427 Toronto
mshred
Toronto
An 8.8 will probably go into whatever vehicle I build next. I think it would be a good option for you- They can take quite a beating, don't weigh a ton, have good aftermarket support, and are plentiful and cheap in local u pull it yards ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DTM_Motorsports]
#1648451
08/01/14 07:50 AM
08/01/14 07:50 AM
Posts: 15,487 Florida
scratchnfotraction
rear shackle flip with A-body 8 3/4 12" rim 29x15x15 M/T tubbed flush with frame rails bolts in on 43" spring centers. I have used a 94 jeep 8 1/4 that has the same 43" perch centers same as d-150/A-body for a narrow bolt in axle under the trucks. D60 with bars/coils ![](/ubbthreads/images/graemlins/drool5.gif)
