Page 2 of 3 1 2 3
Re: Building a d150 street strip. [Re: quickd100] #1648432
07/28/14 07:22 PM
07/28/14 07:22 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
JeeseR, what can you tell us about the Moroso front coil springs? How did they help? better front lift? how hard was the installation? Do you remember the part# Thanks
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Building a d150 street strip. [Re: 11secdart] #1648433
07/28/14 08:40 PM
07/28/14 08:40 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
The moroso part number is 47180, they are listed as camaro or nova springs in the catalogs. It took me a few times to get my ride height where I wanted it but other than that pretty simple installation. Just be careful when you cut them because they are a smaller diameter material so they will be significantly longer than the stock ones. They made more difference dollar for dollar than any suspension changes I have ever made. They really help throw the weight of the heavy nose. Hope this helps, jesse
82' dodge pickup with a 499 low deck
Re: Building a d150 street strip. [Re: JesseR] #1648434
07/29/14 07:09 PM
07/29/14 07:09 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Thanks a lot Jesse, was it ok on the street with the springs or was it a track only set-up, Thanks Again
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Building a d150 street strip. [Re: 11secdart] #1648435
07/29/14 09:59 PM
07/29/14 09:59 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
I drove it a lot on the street but it definitely wouldn't handle the bumpy roads as well. The front would float a little, it settled down pretty quick though.
Re: Building a d150 street strip. [Re: JesseR] #1648436
07/29/14 11:06 PM
07/29/14 11:06 PM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
How much did you end up cutting off of the springs? I have a set of those springs we had in a Dakota, but they were cut 1 1/2 coils for them to work with the Dakota. I'd like to use them in my 75 d100 if they won't end up being too short.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Building a d150 street strip. [Re: andy3965] #1648437
07/29/14 11:41 PM
07/29/14 11:41 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
I'm thinking I cut two coils off, my truck sits really low in the front though.
Re: Building a d150 street strip. [Re: JesseR] #1648438
07/30/14 12:20 AM
07/30/14 12:20 AM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
Mine sets pretty low now. I have stock springs with 1 coil cut now. I think I will give the trick springs a try and see if it makes much difference.
Re: Building a d150 street strip. [Re: andy3965] #1648439
07/30/14 12:34 AM
07/30/14 12:34 AM
junction city oregon
V
viperblue72 Offline OP
V
Andy is that a stock width rearend? Tubbed? Looks like a 315 drag radial? 15x8 wheel?
Re: Building a d150 street strip. [Re: viperblue72] #1648440
07/30/14 12:42 AM
07/30/14 12:42 AM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
It's a 70 truck housing, stock length. I installed it on top of the leaf springs, just had to weld on new perches. It is a 315 drag radial on 15x10 wheels with 6.5in backspace. They tuck real nice!!! I did have to tub it. If you roll the wheel well lips you might can get away with less backspace and not have to tub. I already had the wheels so I just tubbed it to the frame rails.
Re: Building a d150 street strip. [Re: andy3965] #1648441
07/30/14 02:25 AM
07/30/14 02:25 AM
V
V
Thank you for the info. I have a set of 295/65 laying around along with a 70 housing, but with the big bolt pattern. I may use it for a starting point.
Re: Building a d150 street strip. [Re: viperblue72] #1648442
07/30/14 11:12 AM
07/30/14 11:12 AM
Lehigh Acres, Florida
rickstershemi Offline
Might want to look at replacing the lower a-arms with pocketed units from a 3/4 ton Van.....do a search in the truck forum....there's tons of info. With those a-arms you might not have to cut any coils...???
It's a pretty straight forward swap.....
Here's how ours sat with the pocketed a-arms and stock height coils....
Rickster
Re: Building a d150 street strip. [Re: viperblue72] #1648443
07/30/14 11:18 AM
07/30/14 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I like your thinking...mainly because I want to do the same thing on my next build (unless I turbo this car). I was going to use 2 turbos and put them righ behind the cab. Much easier to fab up that way. That set-up isn't going to have a ton of power so your stock rear (unless it's an 8.25) should be ok. You might want to fab up a plate and run an adjustable pinion snubber. Later on you'd probably want to run a cal-trac system or something like that. That red truck is TIGHT!
Coming soon!!!!
Re: Building a d150 street strip. [Re: Mr.Yuck] #1648444
07/30/14 08:52 PM
07/30/14 08:52 PM
V
V
Unfortunately it is an 8 1/4. I know a 9 1/4 would hold up buti do not likec-clip axles.
An 8.8 is alwaysa budget option too.
Being a turbo Street/strip truck I don't plan on it leaving extremely hard.
But probably in the high 1.5s.
Re: Building a d150 street strip. [Re: viperblue72] #1648445
07/30/14 10:23 PM
07/30/14 10:23 PM
8.8 Would be a good choice.....although we ran in the 8's 1/8th mile with an 8.25....still have a suregrip 8.25 sitting on the shelf....
Rickster
Re: Building a d150 street strip. [Re: viperblue72] #1648446
07/31/14 02:41 AM
07/31/14 02:41 AM
Toronto
mshred Offline
mshred  Offline
Toronto
An 8.8 will probably go into whatever vehicle I build next. I think it would be a good option for you- They can take quite a beating, don't weigh a ton, have good aftermarket support, and are plentiful and cheap in local u pull it yards
Re: Building a d150 street strip. [Re: mshred] #1648447
07/31/14 11:32 PM
07/31/14 11:32 PM
Mena Arkansas
DTM_Motorsports Offline
Mena Arkansas
Narrowed Dana 60
Tubs
Narrowed frame rails
17.5 inch ET streets
Re: Building a d150 street strip. [Re: DTM_Motorsports] #1648448
07/31/14 11:34 PM
07/31/14 11:34 PM
Mena Arkansas
Mena Arkansas
Another
Re: Building a d150 street strip. [Re: DTM_Motorsports] #1648449
07/31/14 11:38 PM
07/31/14 11:38 PM
Mena Arkansas
Mena Arkansas
Bars
Re: Building a d150 street strip. [Re: DTM_Motorsports] #1648450
07/31/14 11:39 PM
07/31/14 11:39 PM
Mena Arkansas
Mena Arkansas
Tubs
Re: Building a d150 street strip. [Re: DTM_Motorsports] #1648451
08/01/14 07:50 AM
08/01/14 07:50 AM
scratchnfotraction Offline
rear shackle flip with A-body 8 3/4 12" rim 29x15x15 M/T
tubbed flush with frame rails
bolts in on 43" spring centers.
I have used a 94 jeep 8 1/4 that has the same 43" perch centers same as d-150/A-body for a narrow bolt in axle under the trucks.
D60 with bars/coils
Page 2 of 3 1 2 3
