Re: baddest small block combo ever
[Re: B1Fish540]
#164749
12/18/08 07:49 AM
12/18/08 07:49 AM
Posts: 6,187 Melbourne , Australia
LA360
The demand just isn't there for P5 heads. I don't think Mopar has produced them in years. Supply is that poor that as I mentioned in a previous post, a local racer running in Pro Stock has his own P5 style head cast locally.
AL....
Alan Jones
[Re: LA360]
#164750
12/18/08 08:02 AM
12/18/08 08:02 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
There was a set of P5's advertised on here last month I believe or it may have been on RJ. Can't find them now so they may have sold. Nice Christmas present for someone! Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: LA360]
#164751
12/18/08 05:01 PM
12/18/08 05:01 PM
Posts: 426 Cairns Queensland Australia. T...
vc360
AL....
I thought Slawko did their heads AL. Some guys on his team dont know its a small block lol.
[Re: Plumb Wired]
#164752
12/18/08 05:01 PM
12/18/08 05:01 PM
LA360
I know Patterson's had a set of castings listed on their garage sale section of their site for quite a while, whether they sold or not, who really knows. AL....
Alan Jones
[Re: LA360]
#164753
12/18/08 05:18 PM
12/18/08 05:18 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
There were acouple 358 inch P5 complete motors for sale in National Dragster last month?
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: FASTFISH420]
#164754
12/18/08 06:44 PM
12/18/08 06:44 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
There was a P5 engine complete at the Mopar swapmeet in Indy last year. Most people walked by scratching their heads. Someone asked me what it was. I told them for the size the baddest small block setup going to date. That got repeated several times before I could walk out of hearing range. LOL
[Re: FASTFISH420]
#164756
12/19/08 10:02 AM
12/19/08 10:02 AM
Posts: 189 long island new york
kingdust
is your new motor close to the old combonation with more cubes or a whole new combo? what gear and tire are you running to go through at 9300?. are you limited by the class rules. im going to run the ram N/A gforce 10.5 class this year, i think i can be competitive. theres like 3 or 4 cars going high 850s 860s and its a all run field so if i can run 9.0s high 8s i'll be good. i have a good car i just have to refine a few things. hope that motor turns out good for you. MARK.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: b1n02cuda]
#164757
12/19/08 11:08 AM
12/19/08 11:08 AM
kingdust
i never said i had spray on the car. But i here what your saying, like i said in my first post everything would have to be rite to run those #s. im sure those guys your talkin about have alot of experience and been at it along time, ( i dont know who they are by first names). maybe you thought i thought it was going to be an easy deal, i know no matter how much HP you have you have to get to the ground, i know what the motor made on the dyno, i also know we could have got more from it, but after 10 pulls and all day there we decided it was enough and were happy.i put the motor in the car and after a little testing it showed good #s and theres still alot i have to iron out. so if i hit those #s this year, great! if not i'll come back hard next year, doesnt make those guys any less knowledgable. like you said everything has to be rite, track,weather,tuneup etc. and hard work. we dont have a track on long island, i got to travel 3 hrs to atco just to test! sometimes i only get 2 runs and you cant learn hardly anything. so it might take 3 years! take care.
[Re: SHEPP]
#164759
12/19/08 06:50 PM
12/19/08 06:50 PM
Posts: 12,523 Kalispell Mt.
HotRodDave
Kalispell Mt.
Do you guys consider the new hemis small blocks? Just wondering every ones opinions.
[Re: HotRodDave]
#164761
12/19/08 11:03 PM
12/19/08 11:03 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
well....depends on your definition of a small-block....
you're looking aftermarket block for strength.....
a P5 head probably has more raw HP potential than any W7/8/9, but there, you're talking very little in common with a factory SBM, save maybe bore centers.
bar none, the latest 5.7/6.1 hemi package has the most potential power of any stock "small block mopar" layout. they share bore spacing, bore, stroke, & main bearing size with older LA...
...realistically the OEM 6.1 heads, max ported, have as much raw flow potential as a W7/8/9, plus the added benefit of no valve shrouding due to the valves opening up away from the bore...
[Re: ValiantRich]
#164765
12/20/08 10:26 AM
12/20/08 10:26 AM
Posts: 6,001 Anoka County, MN
Leigh
Anoka County, MN
My SS/BM 69 Valiant has run 8.65 @ 154 at 3,050 lbs. with a 374" W8 motor. I run a 33" tall tire with 5.83 gears, 8,500 stall converter, shift at 9,400 and go over the line at 9,900.
Given the fact that your car is only 50 lbs lighter and 14 fewer cubic inches than my Dart, I can only imagine how much fun that deal is to point down the track. Awesome.
[Re: ValiantRich]
#164766
12/20/08 10:44 AM
12/20/08 10:44 AM
Posts: 2,030 Trumbull,CT.
jim sciortino
Trumbull,CT.
Now that is a cool car!!!
[Re: Get-X]
#164768
12/20/08 11:20 AM
12/20/08 11:20 AM
HotRodDave
Kalispell Mt.
SS/BM Valiant! Awesome car, must be a riot to drive/hear as it's buzzing thru the traps at 10,000 RPM
Got a vidio with sound
