battery kill switch diagram #1647054
07/15/14 10:59 PM
07/15/14 10:59 PM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
Hello all,
Been a long time since I've been here, just been busy as usual. Quick question. Have a trunk mounted battery. Need to install a kill switch for it. I currently have one with only the two hot leads on it, not the type that has the two hot leads and the jumpers, I guess they are called. Can I use the one I have and if so, a diagram how to wire it in? Thanks in advance,
Re: battery kill switch diagram [Re: 67dodge67] #1647055
07/15/14 11:38 PM
07/15/14 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hello all,
I will assume you run a alt.. but you run 1 HOT lead
from the + on the battery to one side of the master
then from the other side of the master to the starter....
if you run a alt you run the big output off the alt
to the back and hook it up on the battery side of
the master... this is the simplest way to hook it
up but there are other ways with relays and such ..
sorry I dont have a diagram
Re: battery kill switch diagram [Re: MR_P_BODY] #1647056
07/16/14 07:42 AM
07/16/14 07:42 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I use a continuous duty relay in mine to kill alternator when the switch is off.
Re: battery kill switch diagram [Re: Bigcube] #1647057
07/16/14 10:57 PM
07/16/14 10:57 PM
WI, USA
mopar addict
mopar addict
WI, USA
Did exactly what you show here, checked it twice as well... hit the switch and it remained running. Not sure where to go from here... bottom line is I need to have it work before I go to the track; yep tech said ya gotta have one with a trunk mounted battery. Nothing has changed (factory wiring harness, etc.) from day one when I got the car. Will see what I can find for info, greatly appreciate your help here.
Re: battery kill switch diagram [Re: 67dodge67] #1647058
07/16/14 11:01 PM
07/16/14 11:01 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Put a single wire GM alternator on it. Then it works just fine.
Re: battery kill switch diagram [Re: 67dodge67] #1647059
07/16/14 11:04 PM
07/16/14 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Disconnect the alt wire from the alt then flip the
master off.. see if it dies then... but your picking
up power from the alt... thats why I hook the alt wire
up to the battery side of the master.. nothing to go
wrong... just to test the master unplug the field wires
at the alt(does the same thing as un bolting the output wire
Re: battery kill switch diagram [Re: MR_P_BODY] #1647060
07/16/14 11:07 PM
07/16/14 11:07 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The only thing about doing it that way Mike if the alternator wire is hot all the time. With a solenoid the power to the alternator is dead when the switch is off.
Re: battery kill switch diagram [Re: Bigcube] #1647061
07/16/14 11:27 PM
07/16/14 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The alt is hot all the time in a production car.. no
big deal
Re: battery kill switch diagram [Re: MR_P_BODY] #1647062
07/16/14 11:33 PM
07/16/14 11:33 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
It is when you don't disconnect the battery and start to pull the motor and make sparks disconnecting the alternator
I'm lazy, I only want to throw the switch and start wrenching under the hood.
Re: battery kill switch diagram [Re: Bigcube] #1647063
07/17/14 12:31 AM
07/17/14 12:31 AM
WI, USA
mopar addict
mopar addict
WI, USA
Thanks for the input guys. I greatly appreciate it. Tomorrow is another day... will see what happens then. Thanks, Dave
Re: battery kill switch diagram [Re: MR_P_BODY] #1647064
07/17/14 12:39 AM
07/17/14 12:39 AM
WI, USA
mopar addict
mopar addict
WI, USA
Quick reply... disconnected the wire from the alt (no longer have the relay hooked up as shown in the diagram above) did not die, kept running. Scratching head there... but again, will wait till tomorrow to pick up where I left off.... more help is always greatly appreciated. Thanks again,
Re: battery kill switch diagram [Re: 67dodge67] #1647065
07/17/14 01:06 AM
07/17/14 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Use a ohm meter and check the master to make sure
it goes open when it shut off
Re: battery kill switch diagram [Re: MR_P_BODY] #1647066
07/17/14 01:55 AM
07/17/14 01:55 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Here is a Diagram without a trunk mount relay
Re: battery kill switch diagram [Re: b1dartsport] #1647067
07/17/14 02:12 AM
07/17/14 02:12 AM
b1dartsport Offline
b1dartsport  Offline
Here is a Diagram with the trunk mounted Ford Relay or Solenoid that a lot of Racers use. I know this is not what you are asking for but these are diagrams of systems that work. Maybe it will give you some Ideas.
Re: battery kill switch diagram [Re: b1dartsport] #1647068
07/17/14 02:26 AM
07/17/14 02:26 AM
b1dartsport Offline
b1dartsport  Offline
Here is another one that is used a lot.
Re: battery kill switch diagram [Re: 67dodge67] #1647069
07/17/14 10:03 AM
07/17/14 10:03 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
This has always kind of amazed me. NHRA wants the positive wire switched, when the most effective/easiest way, is to put the switch on the negative wire. One wire, one master switch and you're done. When the negative side is open= no current flow= nothing works/runs.
If you like drag racing, support your local track.
Re: battery kill switch diagram [Re: CHAPPER] #1647070
07/17/14 04:19 PM
07/17/14 04:19 PM
WI, USA
mopar addict
mopar addict
WI, USA
Thanks for all the replies and input. Will see what I can over the weekend to get this sorted out. Thanks again!!
Re: battery kill switch diagram [Re: 67dodge67] #1647071
07/17/14 04:36 PM
07/17/14 04:36 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did this with mine and it works great. However I need to somehow wire my relay to key on power otherwise it drains the battery if I leave the kill switch on.
68 Barracuda Formula S 340
Re: battery kill switch diagram [Re: Bad340fish] #1647072
07/17/14 05:08 PM
07/17/14 05:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Correct. On a race car where you come back to the pits and throw the switch off, wiring as shown above is fine.
You throw the switch on a car with a ford relay and alt line CD relay, nothing is hot outside a 2 foot or so cube in most cases.
Wiring does get a little busy, but, my car isn't burning to the ground because an alt line is hot all the time. Seen it happen, no thanks.
Re: battery kill switch diagram [Re: b1dartsport] #1647073
07/18/14 01:39 AM
07/18/14 01:39 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
If you don't like the charge line hot all the time you can use a large diode or wire direct to the battery and put a solenoid that is activated by voltage after the kill switch so when you turn off kill switch it kills solenoid and with it wired to the battery there will be no charge voltage to keep it alive. The reason the disconnect is on the positive instead of negative side is some alt. will full field and fry things when you remove negative. You can do the same thing on the ground side to by putting the ground through a solenoid and activating it on the output side of the disconnect the same way as the charge line you just need to get a solenoid that has two wires so you can run the other side to the battery side ground or it will not turn back on. I used to do rv repair they do all kind of disconnects and charge diodes on them. I just realized that big cube put a diagram that shows it perfectly.
