Re: Carb & Tires Plus Boost New Best
[Re: dizuster]
#1645675
07/13/14 07:38 PM
07/13/14 07:38 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
I should have worded that different. When I said "traction control" I should have written control of traction.
Don't use a 2-step. 1.65 60fts rolling in the gas I thought was pretty decent. OEM style rear shocks. At part throttle hooks good. Full throttle spins instantly. Trying to turn the tire too fast. Once it slips it can't recover till car is rolling. On my stickcar you can lessen the wheel stand by RAISING launch RPM
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 1980volare]
#1645678
07/13/14 09:29 PM
07/13/14 09:29 PM
6bblFLASH
N.E. Ohio
Okay I'll look into a set. Thanks
