Re: Which 72-93 truck should I buy? [Re: torredcuda] #1644265
07/10/14 03:21 PM
07/10/14 03:21 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
75 - mid 79(80 for sure) were full time I do believe
72-74 was part time with a divorced transfer case
Re: Which 72-93 truck should I buy? [Re: torredcuda] #1644266
07/10/14 04:13 PM
07/10/14 04:13 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
So which years have the fulltime 4wd, I see the `77 military trucks have it?
Full-Time 4WD NP203 Transfer Case rigs....
1975-1979 all dodge truck models 100-400
1974-1979 ramcharger and trailduster
1972-74 trucks used NP205 gear driven t-case which was remotely mounted(divorced), and front axles used drum brakes
1980-1993...100 thru 300 with the Dana 44 front axle used the Aluminum NP208 or NP241 transfer case, and in 1985 went to CAD axle
1980-1993 200 and 300 series with the Dana 60 Front axle used the NP205 transfer case.
All 1975-1993 had Disc Brakes
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Which 72-93 truck should I buy? [Re: dynotune440] #1644267
07/10/14 05:23 PM
07/10/14 05:23 PM
Lehigh Acres, Florida
rickstershemi Offline
Never minded the drum brakes on the 73 it stopped just fine
Rickster
Re: Which 72-93 truck should I buy? [Re: Soopernaut] #1644268
07/11/14 03:31 PM
07/11/14 03:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Is an 80-84 front disc brake axle a bolt in for a 72-74 truck? I suppose you may have to swap master cylinders.
As long as gear ratio is the same. They bolt in a little diff but will swap. You can also swap just the knuckles out from any 80-93 and install it on the 72-74 axle
Re: Which 72-93 truck should I buy? [Re: 76dodgeboy] #1644269
07/15/14 01:55 AM
07/15/14 01:55 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
I prefer a 70s front axle,with 80up stuff from ball joints out.
.....no axle disconnect,have lockouts,disc brakes,decent wheel bearings.best of both worlds.
Re: Which 72-93 truck should I buy? [Re: bbtrux] #1644270
07/17/14 07:29 AM
07/17/14 07:29 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Thats what an 80-84 axle is.
Re: Which 72-93 truck should I buy? [Re: RODHALL] #1644271
07/17/14 08:38 AM
07/17/14 08:38 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
88-93 would be my perfered years... here is why
1 88 start of the Cummins...
2 fuel injection on gas trucks.
3 NP241 on gas trucks NP205 on Cummins and 1 ton trucks...
Body parts exchange on 81-93 trucks Less the 91-3 rad supports...
5 727 88 / A518 89up trans Cheep if needed rebuilds
6 Dana 60 fronts on CTD and most 1 tons... must have np205 gear drive transfer...
7 full door panels and headliners and trim, on most upgraded models..
* fuse box that don't melt or catch fire like on 76-80 trucks...
9 Not full time4x4... 72-80 trucks...
I think I hit most of it...
The heater fan and the running lights fuses both melted in my 92 along with the ignition and headlight switches.
Several problems Dodge never fixed for 22 years.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Which 72-93 truck should I buy? [Re: moparmarks] #1644272
07/17/14 08:46 AM
07/17/14 08:46 AM
moparmarks Offline
moparmarks  Offline
Plus all the 72-93 had problems with the cowls cracking. Another problem for 22 years that Dodge didn't fix.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Which 72-93 truck should I buy? [Re: 76dodgeboy] #1644273
07/17/14 08:50 AM
07/17/14 08:50 AM
moparmarks Offline
moparmarks  Offline
Chevy disc is a real conversation on the 72-74 4x4. 72-74 D100 had disc.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Which 72-93 truck should I buy? [Re: moparmarks] #1644274
07/18/14 04:44 AM
07/18/14 04:44 AM
PHOENIX
8T2TOP Offline
8T2TOP  Offline
PHOENIX
I was wondering if I should sell my super clean 98 5.9mag 2wd std/short for a 92-93 d150 LE loaded,JY's have no D'S and the 94 ups if there is some,usually stipped to shells?
