School me on Air Compressors #1643072
07/06/14 10:17 PM
07/06/14 10:17 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Guys,
I'm finally breaking ground on my garage after moving 2 years ago. I left a MADE in the USA big daddy compressor at my old shop. Hated to do it, but had to.
So, for the new shop, what are the better brands out there? What should I stay away from? Options I should get? I will be using it for mostly mechanical work. If I paint any, it will be small items. I would like to be able to run two 3/8" drive ratchets with it at the same time. That will be rare, but nice to have the capacity should I need it. My 2-post lift is electric. So, what size would you recommend? Lastly, what are some prices of said units, so I can budget accordingly.
Thanks!!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: School me on Air Compressors [Re: Dixie] #1643073
07/06/14 11:58 PM
07/06/14 11:58 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Can't give you a lot of advice but we are looking into a brand called Bel-Aire. I believe, but not 100% sure they are US made. The model we are looking into is a 60 gallon vertical tank that has a 2Hp motor so runs on 110, not 220. This is important as our inverter is only 110 volt. The battery bank is plenty big so no worries there. We are thinking of a second inverter that would give us backup and wired in series could give 220 but I think the 2 Hp will be fine. The reviews I have read several all mention that it is very quiet. 699 at AirCompressorsDirect.com. No personal experience yet but that is what we will likely purchase. We will be using it for some painting of car panels, inflating tires, some small air tools (die grinders) and when we start building the boat at least one air staple gun as cold moulded construction even with a vacuum bag means lots of staples. Actually very similar duty cycle to what you describe it sounds like.
There was a good thread a few months ago about plumbing the system. Our plan is to use copper for the low corrosion and cooling properties.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: School me on Air Compressors [Re: Dixie] #1643074
07/07/14 12:01 AM
07/07/14 12:01 AM
Kirkland, Washington
Pacnorthcuda Offline
Dixie....the first question is do you have 220 volts available??? That changes everything.
Re: School me on Air Compressors [Re: Pacnorthcuda] #1643075
07/07/14 02:02 AM
07/07/14 02:02 AM
Dixie Offline OP
Dixie  Offline OP
Sure, I'm building the garage now. So, I can install whatever service I want. I plenty of power on tap.
Re: School me on Air Compressors [Re: Dixie] #1643076
07/07/14 02:12 PM
07/07/14 02:12 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Low pump speed is where to start - nice and quiet, less water and easy on parts.
I have a 5hp 2-stage-80 gal Champion (USA) and you can stand next to it and have a conversation, it just lugs along.
For me it was a toss up between quincy and champion, I ran both side by side at TP Tools
Re: School me on Air Compressors [Re: Dixie] #1643077
07/07/14 02:29 PM
07/07/14 02:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Don't know if you know any salesmen that sell lifts and garage equipment? That's who I would start with. Then craigs list second.
Like said above, 220 volt and slow(1750) RPMs
Re: School me on Air Compressors [Re: Challenger 1] #1643078
07/07/14 04:22 PM
07/07/14 04:22 PM
Dixie Offline OP
Dixie  Offline OP
Is single phase good enough?
Re: School me on Air Compressors [Re: Dixie] #1643079
07/07/14 04:59 PM
07/07/14 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm a big fan of Speed-Air (Grainger) compressors, I have an earlier version of the one below and it's still running perfectly after 35+ years of pretty hard use. Not cheap.
http://www.grainger.com/product/SPEEDAIRE-Electric-Air-Compressor-4XA59?functionCode=P2IDP2PCP
I believe they still use Champion pumps.
Re: School me on Air Compressors [Re: Dixie] #1643080
07/07/14 05:31 PM
07/07/14 05:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes it's what you want in a residential setting. It'll cost a little more up front but then you won't have to deal with a phase converter.
Re: School me on Air Compressors [Re: Challenger 1] #1643081
07/07/14 05:47 PM
07/07/14 05:47 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
For a constant supply of air when needed your best bet is a two-stage compressor. They supply significantly more air (cfm)than a single stage and cost a bit more but they are worth it. The sellers like to tell you about horsepower but CFM is what's important.
Re: School me on Air Compressors [Re: TooMany62s] #1643082
07/07/14 05:57 PM
07/07/14 05:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
I'm pretty sure he will go 2 stage?
He asked about electrical requirements and usually around residential areas you only have single phase power. And most large compressors come standard with a 3 phase motor because it is cheaper than a single phase motor. If your in commercial area with 3 phase power your best bet to order your equipment for 3 phase power and use it.
Re: School me on Air Compressors [Re: David_in_St_Croi] #1643083
07/07/14 06:45 PM
07/07/14 06:45 PM
Can anyone retrieve that thread please
Re: School me on Air Compressors [Re: Dixie] #1643084
07/07/14 07:32 PM
07/07/14 07:32 PM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
This is the brand that I plan on buying to replace my old compressor when it goes out. http://www.quincycompressor.com/products/reciprocatingpiston.html A friend has one in his professional body shop and he loves it. Not a cheap compressor but good ones usually aren't. I would say 5 to 7 hp would be plenty for your use.
Re: School me on Air Compressors [Re: Fanning] #1643085
07/07/14 07:47 PM
07/07/14 07:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
hi Randy! this has nothing to do with an air compressor but if you're doing electricals from scratch plan on enoth for a welder too. even if you don't weld now ya never know!
Re: School me on Air Compressors [Re: mikemee1331] #1643086
07/07/14 08:07 PM
07/07/14 08:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
I bet Randy will have plenty of power and panel space for anything.
20 years ago I had my 100 amp box taken out of my house and had a 200 amp box installed in the house. Then they put my 100 amp box in my garage. At first it only did one 30 amp 220 plug for a large free gigantic window AC unit. Even the overhead lights feed from the house because that's how it was originally.
Since then I have installed about 10 circuits over the years, 2 50 amp 220 welders plugs, 3 30 amp 220 plugs for pressure washer, hot tub(GFI), and window AC. Then I have a 30 amp 125 volt plug for my RV in the drive and lot's more. Have like 4 20 amp plug circuits. Most of it is to code as I hang out with 2 electricians friends and have done plenty of electrical work in the past at work. Once you have the service anything goes just as long as it's single phase.
Re: School me on Air Compressors [Re: Challenger 1] #1643087
07/07/14 08:11 PM
07/07/14 08:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
awesome info!! thanks!
Re: School me on Air Compressors [Re: mikemee1331] #1643088
07/07/14 09:53 PM
07/07/14 09:53 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
This is NEVER my answer when it comes to tools, but... Harbor freight. I bought their 60 gal two stage 220 compressor. It came with a year and a half warranty and is made from a USA can and a euro pump. Assembled in the usa. The same unit is badge engineered as a bel-aire and some other units (same piece, different paint and stickers). The selling points were a slightly lower price, not china made, and it was in stock I paid cash and left with it in my truck.
It easily runs a longboard air sander no problem and kicks on and off while sanding continuously- didn't stay on like a weaker pump. It's not the quietest but not bad at all.
Re: School me on Air Compressors [Re: mikemee1331] #1643089
07/08/14 01:43 AM
07/08/14 01:43 AM
Dixie Offline OP
Dixie  Offline OP
Thanks guys!! Yes, I'm planning to get a 2 stage compressor.
Mike, I was just thinking I need a welder today. Thanks, great idea!
Re: School me on Air Compressors [Re: Dixie] #1643090
07/08/14 03:33 PM
07/08/14 03:33 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Did this a few years ago myself, here is what I learned..
Not until over 7.5 HP do you have to worry about 3 phase.. If your in a residential neighborhood you probably do not have 3 phase available.
For most apps, single phase is fine..
We are talking REAL 5-7.5 hp here, not the little craftsman type of compressors.. Go look at the big ones, you will see what I mean..
Slow revs is the way to go.. Be advised that most 7.5 HP compressors are just 5hp with different pulleys to spin them faster ( Noisier also)
I purchased an old Saylor Beale and rebuilt it, sure miss it.....
Re: School me on Air Compressors [Re: floridian] #1643091
07/08/14 03:48 PM
07/08/14 03:48 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
Randy,
Have a look at Eatons. Been very happy with them at our shop and hangar.
talk to you at the NATs.
mike
http://www.eatoncompressor.com/catalog/item/504747/206953.htm
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
