Re: magnum head ?
[Re: dustpan man]
#164142
12/08/08 01:39 AM
12/08/08 01:39 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
The 318 and 360 Magnum heads are the same. Bolting them onto a 75 360 isn't TOTALLY straightforward, though. The Mags oil the rockers through the pushrods and have individual rockers. There are conversion pieces readily available.
The intakes are different, but Mag heads can be redrilled to accept LA intakes, or you can use a Magnum specific intake, I believe available from MP, Edelbrock, or the Professional Products "Crosswind".
2 Demons...no, not my kids!
Re: magnum head ?
[Re: OzHemi]
#164145
12/08/08 02:24 AM
12/08/08 02:24 AM
RapidRobert
The MP pushrods for this conversion may end up being too short, mock everything up before you make a decision on ordering pushrods.
Re: magnum head ?
[Re: MarkZ]
#164149
12/08/08 04:56 PM
12/08/08 04:56 PM
Posts: 2,826 NY usa
540challenger
NY usa
My dad was looking for a set to put on a LA 360, but they don't look like they could flow a lot of air stock.
They do, more than a stock J head could ever muster.
I had a lengthy conversation with another board member here and he mentioned Mag heads off of a 318 being less prone to cracking than those off of 360s. Makes sense when you think about it. Maybe the 360s were ran leaner to pass emissions standards?
I have a set off of a 100k+ 318 Mag and they came back crack free.
I think the 318 heads were produced in a different foundry then the 360 head
Re: magnum head ?
[Re: 540challenger]
#164150
12/08/08 05:30 PM
12/08/08 05:30 PM
Posts: 15,487 Florida
scratchnfotraction
you will need the oil through flat tappets and the hollow conversion pushrods from MP/dealer to run mag heads on a older LA engine block these 2 things are a must to run mag heads on a non-mag LA block the intake has options as mentioned above if your block is a pre-mag LA roller block then you can use the mag roller lifters and stock pushrods and mag heads
Re: magnum head ?
[Re: RapidRobert]
#164154
12/09/08 12:37 PM
12/09/08 12:37 PM
Posts: 1,396 Mass
dgc333
Mass
The conversion push rods are 7.625" long. In my application I wound up odering 7.650" long push rods. This length was a stock length for some other application so they were off the shelf from Summit.
Re: magnum head ?
[Re: dustpan man]
#164156
12/10/08 08:45 AM
12/10/08 08:45 AM
Posts: 2,826 NY usa
540challenger
NY usa
are the valve covers the same
No the magnum and La covers are different
Magnum have ten bolt covers
LA 5 bolt
Plus the cover gasket is shaped a little different from magnum to la.
However many guys have been able to install LA covers on Magnum heads with no leaks.
Re: magnum head ?
[Re: dustpan man]
#164157
12/10/08 09:16 AM
12/10/08 09:16 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
Here is a pic of Magnum covers on my car. I think they look pretty good.
Re: magnum head ?
[Re: dgc333]
#164159
12/10/08 11:14 AM
12/10/08 11:14 AM
Posts: 10,502 Chicago, Illinois
Devil
Chicago, Illinois
I like these valve covers, I plan on putting these on my RamCharger when I get the chance. Got them for a really good deal too! But as was said before, LA style valve covers can fit. Ryan
Re: magnum head ?
[Re: Devil]
#164160
12/10/08 06:23 PM
12/10/08 06:23 PM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
So for a magnum head conversion set up, what are the costs for the valvetrain items for a .500" lift hyd flat tappet cam? - lifters, pushrods, rocker arms and studs. Can regular run of the mill small blk chevy rocker arms be used? Been comparing an Engine Quest magnum head conversion to a set of ready to run Edelbrock LA heads. I think after the conversion is complete with the magnum type heads the cost would be comparable to staying with the LA setup but with new Ebrocks.
Keep old mopars alive.
