Re: Engine temp before doing burn out?
[Re: 68LAR]
#1641310
07/02/14 06:39 PM
07/02/14 06:39 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
I like to pull into the water at 130. Cooler is definitely better but doing the same thing every time is more important in bracket racing.
[Re: Guitar Jones]
#1641311
07/02/14 07:29 PM
07/02/14 07:29 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I usually drive to the track so its heated up when I get there but even making a time run I have to wait a bit. I am usually about 150 when I start my burnout. And the last time racing I put 4 passes on it and went 2 rounds and the car never went over 180 all day. I really dont like mine over 160 when I start my burnout. Ron
[Re: 68LAR]
#1641313
07/02/14 07:53 PM
07/02/14 07:53 PM
Posts: 7,506 Az
Crizila
Az
I try to go in at about 150 oil temp. I run a filled block, so my water temp rarely goes over 190. When I get back to the pits my oil temp is around 200 / 212.
Fastest 300
[Re: 68LAR]
#1641315
07/02/14 10:47 PM
07/02/14 10:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What's your engine temp before you go into the burn out box. Any thoughts on which is better, warmer or cooler?
You dont even state what fuel... I use to hit the box at 160 on E-85 and hit the line at 165.. but I have learned maybe 180 at the was better on E-85 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: cudaman1969]
#1641320
07/04/14 11:30 PM
07/04/14 11:30 PM
Posts: 1,444 central ohio
nss guy
central ohio
Does'nt matter, leave at 200 with alum. heads, use the heat to make power. I lost two tenths leaving at 160.
ditto on the 200 temp w/ aluminum heads, my car runs the fastest hot. look at what the new vehicle normal temps are 210f
[Re: E-Ticket]
#1641322
07/05/14 01:58 AM
07/05/14 01:58 AM
Posts: 2,530 PA
moparacer
PA
I go in the water at 150, try to stage around 160 and its usually 165-170 in the shut down.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: cudaman1969]
#1641325
07/06/14 09:03 PM
07/06/14 09:03 PM
Posts: 5,875 communist bloc of new jersey
jamesc
no secret how to increase engine output with temperature but try going round robin/hot lapping with those temps
[Re: Guitar Jones]
#1641327
07/07/14 09:27 PM
07/07/14 09:27 PM
Quicktree
same here
[Re: Quicktree]
#1641328
07/07/14 10:17 PM
07/07/14 10:17 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
After waiting a few days and re-reading some of these replies, I'm really confused. First off, I run a aluminum head. My temp even on the hottest days or running round robin,never gets above 175*. I run 93 octane pump gas. My best times have been with going into the box at around 160*. I tried changing to a hotter thermostat (180*) for an 1/8th mile race a few weeks back, but the car ran 2 tenths slower in the 1/8th. My 60' times were also off a bit. So I'm confused. ![](/ubbthreads/images/graemlins/confused.gif)
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
