Page 2 of 14 1 2 3 4 13 14
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639342
06/28/14 08:17 PM
06/28/14 08:17 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Do you have a Passon 5 speed? If so, that is what the car needs to really be a dual threat. Have Doctor Diff change the 2.94 rear gears over to something in the upper 3's, add the Passon 5 speed and that car becomes a fire breather.
He does... The Passon 5-speed has a final gear ratio of 0.70:1. So, if my math is correct, even 4.10's would put it with an equivalent gear ratio as a standard 833 with a 1:1 ratio with 2.87 gears out back.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639343
06/28/14 08:18 PM
06/28/14 08:18 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
AndyF, do you feel it's a bit compromised and undergeared for the track currently? Or overgeared for the street? Or?
Did Tim get to take it on the track with the Milodon pan and new sway bar setup?
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639344
06/28/14 08:19 PM
06/28/14 08:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, I could certainly do that. Ironically I also have a brand new 3.91 center section from Dr. Diff right now and as of today, have not installed the Passon unit in the Duster (was planned this week). I could easily toss in the stock 3 speed and leave the Duster more OEM.
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639345
06/28/14 08:21 PM
06/28/14 08:21 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Do it! Do it! Do it!
Re: no talk of Tim's Valiant being for sale here [Re: MuuMuu101] #1639346
06/28/14 08:26 PM
06/28/14 08:26 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
Congratulations on the purchase Scott.
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639347
06/28/14 08:31 PM
06/28/14 08:31 PM
AndyF Offline
AndyF  Offline
The car is set up right now for PIR so the torque curve matches the track speed of approx. 60 mph on the tight corner to 150-160 mph down the front straight. That is why is has the super tall rear end gears. The super tall rear end gears are a little tough on the clutch life when driving around town.
Some 3.70 or 3.90 rear gears with a Passon 5 speed would make the car a stop light monster and still give it 160 mph top speed capability. It was one of things that we wanted to do with the car but just didn't have the budget. Hopefully the Passon 5 speed can handle the torque output of the 427. If so, then the car would be a serious threat to any Vette or Viper.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639348
06/28/14 08:33 PM
06/28/14 08:33 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
IIRC from the Passon 5 speed thread, the transmission has been rigorously tested behind a big block in an A-body pulling lots of trips down the drag strip as well as some track time as well.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639349
06/28/14 08:35 PM
06/28/14 08:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ok, that makes sense.
I believe you guys had a 2.44 1st gear close ratio trans in it once and it was a pain to launch on the street or something?
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639350
06/28/14 10:01 PM
06/28/14 10:01 PM
AndyF Offline
AndyF  Offline
Yes it used to have a close ratio 4 speed but last time Tim rebuilt the tranny he went with a wide ratio in order to get a little more first gear. Driving up onto the trailer killed the clutch at one race which was a bummer. Having a fifth gear would make the car much easier to drive around town and in the pits. But then you have to shift across the gate a couple of times which is a bit of a downside. It would be nice to have a H pattern for 2 thru 5 and then have a granny gear 1st for the pits and pulling on a trailer.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639351
06/28/14 10:11 PM
06/28/14 10:11 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
Do you have any pics of the front sway bar up dates?
Re: no talk of Tim's Valiant being for sale here [Re: kotacars] #1639352
06/28/14 10:43 PM
06/28/14 10:43 PM
AndyF Offline
AndyF  Offline
I don't. Tim finished up the fabrication at his shop so I didn't get any final pictures. It looks great though, very clean, very strong and very simple.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639353
06/28/14 10:58 PM
06/28/14 10:58 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
So the only changes were the addition of the nascar front sway bar?
Re: no talk of Tim's Valiant being for sale here [Re: kotacars] #1639354
06/28/14 11:10 PM
06/28/14 11:10 PM
NY NY
3
340duster340 Offline
NY NY
cool ride and congrats on the purchase. any pics of the cage and firewall to frame rail bars?
Re: no talk of Tim's Valiant being for sale here [Re: 340duster340] #1639355
06/28/14 11:36 PM
06/28/14 11:36 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
WOW He's taking a blood bath on that. I've modeled my build after that car- the B engine withstanding. It's gotta be a tough decision to sell after putting all that work into it.
Re: no talk of Tim's Valiant being for sale here [Re: Skeptic] #1639356
06/29/14 12:18 AM
06/29/14 12:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree. A gory blood bath.
Like going to an open casket funeral that should not be open casket.... It's just very tough to look at.
Tim and AndyF put so much effort and ideas into the car without really trying to get rich marketing a product or make a buck. And there was a emotional rollercoaster of successes and setbacks while pushing the envelop.
No offense or bad will to Scott that bought it. It's was fully for sale. Just sad circumstances.
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639357
06/29/14 12:52 AM
06/29/14 12:52 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Nope! Gonna keep it and drive it! But I will be getting rid of a Duster soon to pay for it.
Which Duster?
Re: no talk of Tim's Valiant being for sale here [Re: dart4forte] #1639358
06/29/14 12:58 AM
06/29/14 12:58 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not the Duster Im building, the driver 340 4 speed car.
Re: no talk of Tim's Valiant being for sale here [Re: Skeptic] #1639359
06/29/14 03:44 AM
06/29/14 03:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I must have missed it, but....
Why the fire sale? Is there some measure of desperation to force such a quick sale at this price?
Re: no talk of Tim's Valiant being for sale here [Re: Kern Dog] #1639360
06/29/14 03:57 AM
06/29/14 03:57 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not particularly quick/fire sale.
It's a car with a limited audience/buyers. Buyer has to be after similiar goals and understand what it takes to get them.
Not an easy car to sell in the current condtion. Doesn't look pretty and shiny. All purpose. No frills, no catchy B-S name given to the car, No Pro Touring/Bling B-S, no big "name" builder behind it, no clever PR team behind it. No one's going to pay the cost of all the trick inside stuff done to it. Just like most modified cars and race cars.
For instance this car sold for around $25-28K. And it's a numbers matching red/red formula S car. And it's got creature comforts and can back it self up at the track: http://www.carcraft.com/featuredvehicles/116_0507_1968_plymouth_barracuda_s340/ It would take an easy $10K+ to make the Valiant look like the Barracuda. And it would still be a 68 Valiant and not a 68 Formula S 340 4spd car.
Re: no talk of Tim's Valiant being for sale here [Re: Kern Dog] #1639361
06/29/14 04:05 AM
06/29/14 04:05 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
oh why oh why am I just reading about this now????? what a killer price for a killer car.
