Re: Anyone running 14" brakes rotors?
[Re: BergmanAutoCraft]
#2218074
12/20/16 11:12 PM
12/20/16 11:12 PM
Posts: 124 Colorado
MoparCar
Colorado
Cass made them many years ago. Aside from some of the Porsches and Stoptech equipped XV cars they are one of the best brake systems I've ever experienced. Thanks-Wes
[Re: 451Mopar]
#2218304
12/21/16 12:29 PM
12/21/16 12:29 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Wes-
I run the same fronts as Peter. I have a few sets of the correct calipers if you wanted to get the correct bracket from Cass and copy the kit.
-Wade
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: 451Mopar]
#2218837
12/22/16 08:09 AM
12/22/16 08:09 AM
Posts: 234 Brisvegas, Australia
Alchemi
I think any of the disc brake setups will be lighter than the 11x3" drums that are on my car now.
Actually no.... I thought that until I had both set ups in front of me on the scales, the 11.75 c-body set up is heavier than 3" drums by a couple of pounds
[Re: 451Mopar]
#2219157
12/22/16 06:11 PM
12/22/16 06:11 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Weight wise, drums are hard to beat.
Mopar to the bone!!!
[Re: Uhcoog1]
#2222928
12/29/16 07:23 PM
12/29/16 07:23 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Wes-
-Wade Were you able to solve the pad knock back issue you had on heavy cornering?
[Re: feets]
#2223617
12/30/16 09:23 PM
12/30/16 09:23 PM
Uhcoog1
Houston Tx
Wes-
-Wade Were you able to solve the pad knock back issue you had on heavy cornering? The hubs you made were a big improvement! Thanks for that
