Re: Thank-You Autometer
[Re: justinp61]
#1638498
06/26/14 02:44 PM
06/26/14 02:44 PM
Posts: 12,423 Taxes & Virus's R-US, NY
Dragula
I've never had an Autometer tach read 0 with the engine not running. No biggie though, I know exactly how many rpms it turning. Never had any issues with any of their gauges that I'm aware of.
If 0 isn't 0, what makes you think your shift rpm is what it is?
[Re: an8sec70cuda]
#1638499
06/26/14 02:48 PM
06/26/14 02:48 PM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
Over the years I have had some issues with Autometer gauges but they have ALWAYS stood behind them and taken care of any issues. SO they are still ok in my book. You may want to send it in they will take care of any issues you have.
[Re: Dragula]
#1638500
06/26/14 03:07 PM
06/26/14 03:07 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
My recall is always very close to the log from my LM-2.
[Re: justinp61]
#1638501
06/26/14 05:53 PM
06/26/14 05:53 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
Well crap. I just spent a ton on a set of Autometer Procomp gauges and tach for my Barracuda project. I'll be wary of them at first. I hope I have better luck than the OP.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 6pak2go]
#1638502
06/26/14 06:22 PM
06/26/14 06:22 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
That's why I like the old school Stewart Warner mechanical gauges....I've never had a problem with them.
[Re: Dragula]
#1638503
06/26/14 06:33 PM
06/26/14 06:33 PM
Quicktree
turn your switch on it will go to zero
[Re: Quicktree]
#1638504
06/26/14 11:40 PM
06/26/14 11:40 PM
Posts: 447 lake charles, la
sc4400
lake charles, la
Having worked with mechanical gauges in industrial settings for more than 30 years, I offer a few observations. ANY mechanical gauge will be permanantly damaged if over pressured more than 10-15 % even ONE time. Because of the nature of the bourdon tube assembly inside, you simply CAN NOT hit them with pressure exceeding their range. Mopars are notorious for high oil pressure capability. I would say your gauge saw @ 138-150 pounds for a moment, and it's over. Which is why I have used 0-200 oil pressure gauges for many years, with great results. In industry, I routinely have 0-300 gauges on service that runs 75-100 PSI. And they are still damaged sometimes by pressure spikes. So I go to 0-400. ![](/ubbthreads/images/graemlins/thumbs.gif) I recently damaged an electric pressure sender on my racepak when I accidently installed the pill holder backwards in my injection pump. it only takes once! If your pressure relief sticks for a moment, or you start a cold motor with thick oil, no gauge will survive. This is one of those issues that no one really analyzes. Get an Autometer 0-200. You'll be happy. And you'll be surprised when you see pressures north of 100 some times!! RIP ![](/ubbthreads/images/graemlins/beer.gif) Also, just because your pressure relief spring is set at say..80 psi, under some conditions it will still build pressure much higher. Oil pumps are what we call positive displacement, meaning that pump WILL move liquid SOME WHERE, even places you won't like. Or break the shaft trying.If you have a combination of tight clearances, high RPM, and thick oil, you get swollen or burst filters, and premature drive gear wear. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Quicktree]
#1638507
06/29/14 11:44 AM
06/29/14 11:44 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
exactly that's how ALL electric tachs that I have seen work. I have had ton of Autometer gauges over the last 30 years and only had 1 stop working.
It was a electric fuel pressure gauge and the problem was the sender not the gauge and called Auotmeter and they sent a new one no charge.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Locomotion]
#1638509
06/29/14 11:58 AM
06/29/14 11:58 AM
Posts: 4,994 new jersey usa
11secdart
new jersey usa
I have used Autometer for years with out any real issues, I had to replace a water temp. gauge once because the tube/ sensor broke. I have their cheaper brand Autogage tach and gauges in my D150 the only problem I had was an oil leak at the fitting in the block which wasn`t their fault.
[Re: Quicktree]
#1638510
06/29/14 12:04 PM
06/29/14 12:04 PM
Posts: 5,898 Florida
Locomotion
X2 I hope. I've seen the same thing. My electric water temp gauge does weird things when I turn the master switch off while the electric water pump is running as well.
[Re: hemi-itis]
#1638512
06/29/14 12:57 PM
06/29/14 12:57 PM
Quicktree
Not sure if I will keep any of these after I complete the Racepak installation
dont blame you, that looks like ricer row ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Quicktree]
#1638513
06/29/14 01:48 PM
06/29/14 01:48 PM
Posts: 2,677 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
So far so good here! I sure don't want to change them either!
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
