Re: Street outlaws tonight
[Re: belv2vert66]
#1637559
06/24/14 02:17 PM
06/24/14 02:17 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I like the show too ! I predict the new Number one to be Monza. Admittedly, I am no drag racing expert and have been around long enough to realize how little I know..... but he seems very consistent and has a confidence about him.
My guess too
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Monte_Smith]
#1637560
06/24/14 02:27 PM
06/24/14 02:27 PM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
Monte you are right. But if thats the case where are all the fast slow cars? The way that Cheifs car left them in the dust there should be anouther five cars in the area that are not on the list that would at least give him a good race. The bottom 5 if I am right are all small tire small block on nitrous making like 1200 HP. Top 5 guys are way beyound that. If this season is going to be about races for the bottom 5 and races between the top 5 its going to get old. I should refraze what I said. Cheif rolled over the bottom 5 guys like they were not even trying. Still really like the show.
If the MODS did their job I would not be hitting the notify MOD button. LOL
[Re: Monte_Smith]
#1637562
06/24/14 04:54 PM
06/24/14 04:54 PM
slippery440
Crybaby440
Crybaby440
Central New York
Thanks for the info. I thought there were more small blocks than there are. 5.0 to 5.50s boy they are flying. That means the top 5 are high 4s to 5.0 and that is fast. Monte you are there and have seen alot of races. To win on the street on a good pass what would you say the are running?
[Re: slippery440]
#1637563
06/24/14 05:01 PM
06/24/14 05:01 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I won't say exactly what they run, although I know all the cars and what they are capable of on the track...........Look back to post 16 in this thread. My last paragraph will give you an idea.........BUT if you are assuming the top 5 or 6 cars are easy 4 sec rides........you would be correct. As to what they actually run on the street......well as with a track, that depends on the surface. But it is not difficult to lay track graphs over street graphs and have a VERY good idea of what kind of lap they made. Suffice it to say they are DAMN FAST
Monte
[Re: slantzilla]
#1637567
06/24/14 05:39 PM
06/24/14 05:39 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Jr. Monza needs to grow a little thicker skin or get used to having his butt pounded.
Yes indeed. When you get whooped like that, just shut up and keep whatever level of dignity you may still have.
I used to call guys like that alligator mouth, parakeet ass.
[Re: slantzilla]
#1637568
06/24/14 06:09 PM
06/24/14 06:09 PM
Monte_Smith
North Alabama
Monte
It's been posted all over that Daddy Dave can go 4:40's. I would guess Chief and Shaun have to be close to that, and Monza right in there too.
Dave's truck is lightest of the bunch and also likely has the best motor. It has a Fulton 632 spreadport with 3 stages.......Doc's Monte is over 3000lbs and has an older 5.0 bore space 706 with 3 stages.......Monza's Camaro is a tick under 3000 with a conv head 632 with 2 stages..........Dominator's Dart has a 632 conv head BBC with two stages, although he hasn't had a chance to ring it out yet........Chief has a Butler built 500 inch Poncho with twin turbos........Murder Nova has a Pro-Line built twin turbo big block. Most all of them have very nice chassis work as well. These are high dollar rides with GOOD parts and their performance reflects that.
NOW.....the turbo cars make MORE power, by a LOT......BUT, on the street they can't use that power and in an 1/8 mile, a fast nitrous car is pretty much impossible for them to run down, given both make clean hits.
Doc is having a hard time getting a handle on the power the new 5.0 motor makes........Dominator has not had a good chance to get his combo ironed out, but Monza and Dave just make clean, fast passes at will it seems. That Camaro(Monza) is just nasty and deadly consistent.
Monte
[Re: Monte_Smith]
#1637571
06/24/14 11:09 PM
06/24/14 11:09 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Season 3 is done and season 4 is shooting right now. Season 3 ended with a NEW number 1 and it is not the car most think, nor one the producers WANTED there.
I was in Paducah KY Saturday night with "Doc" and "Monza". They did an appearance at Beacon Dragway and made some passes with the boards off. They both had tunes in the cars they had just run in Texas "on the street". I saw the slips and the data from both cars. I won't give the ETs, but will only say that if you want to roll with these guys, your ride better "easily" make 4 sec blasts down a city street
Monte
Doc and Monza are Monte Smith N2O cars correct.??
Like the shirts on the tube Monte..
Chris..
[Re: Monte_Smith]
#1637572
06/25/14 12:16 AM
06/25/14 12:16 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
Most everybody knocked the tires off last night against Chief, knowing they would need a really good lick. That makes the racing look more lopsided or staged
Monte
Derick had a good shot at Chief,but was having throttle cable problems and his nitruos didn't come on when he left and was on the motor only for about a second till his second stage came on
[Re: Chris'sBarracuda]
#1637573
06/25/14 12:17 AM
06/25/14 12:17 AM
Monte_Smith
North Alabama
Monte
Chris..
Doc, Monza, Dominator and Andrade are my guys, I did their intakes. I also try and help Dave a little and before they went turbo, both Chuck and Chief had systems from me. Chuck a crossbar plate and Chief had two foggers on that same Poncho motor. I was doing these guys stuff way before this show came along. The Fulton motor that is in Dave's truck, belonged to one of my customers from Georgia and I tuned it at ORSCA races. Ran it in a drag radial Mustang. We never hurt it and Dave seems to hurt it a LOT.........LOL!!!
I also did a crossbar plate for Youngbloods car, but Jerry, his dad told me Sat night that he is too busy chasing tail to work on the car............LOL!!!
Monte
[Re: slantzilla]
#1637574
06/25/14 12:19 AM
06/25/14 12:19 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
Don't really believe Dave can run that quick
[Re: hemiiroc]
#1637575
06/25/14 12:21 AM
06/25/14 12:21 AM
Monte_Smith
North Alabama
Not very likely
Monte
[Re: Monte_Smith]
#1637576
06/25/14 12:24 AM
06/25/14 12:24 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
Monte
Chris..
Monte
Chief's turbo motor is completely different than his nitrous motor that he sold
