Torqueflight 727 Cooling Lines #163750
12/07/08 11:11 AM
12/07/08 11:11 AM
Louisiana
duckblind Offline OP
Louisiana
I am about to install an external transmission cooler on my 68 charger big block with 727 torqueflight. Does any one know if the fluid return line on the transmission is the line the line that connects to the more front part of the transmission or more rear part of the transmission?
Thanks,
Jason
Re: Torqueflight 727 Cooling Lines [Re: duckblind] #163751
12/07/08 11:22 AM
12/07/08 11:22 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Pressure is the front and return is the rear port.
Re: Torqueflight 727 Cooling Lines [Re: duckblind] #163752
12/07/08 11:36 AM
12/07/08 11:36 AM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
add the cooler after the raditor. that way rad does most of the cooling and than cooler finishes it off. make sure a flow of air to cooler
joe
Re: Torqueflight 727 Cooling Lines [Re: skajm] #163753
12/07/08 10:06 PM
12/07/08 10:06 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Re: Torqueflight 727 Cooling Lines [Re: screamindriver] #163754
12/07/08 10:20 PM
12/07/08 10:20 PM
What kinda cooler did you get. The B&M stacked plate super coolers are the best (or a similar design). Much more efficient than the copper tube type and aluminum fins.
Re: Torqueflight 727 Cooling Lines [Re: skajm] #163755
12/11/08 09:23 PM
12/11/08 09:23 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
joe
I asked the TransGo cooler guys. They said skip the radiator alltogether. Said its cooler without. Thats what I did. Just passing it along...
Re: Torqueflight 727 Cooling Lines [Re: Vert] #163756
12/11/08 09:53 PM
12/11/08 09:53 PM
people have opinionated that the rad ccoler is needed to heat the trans fluid in cold weather but I am with the transgo people & use an auxialliary one only(a large one)& keep the trans fluid/coolant totally seperated.
Re: Torqueflight 727 Cooling Lines [Re: RapidRobert] #163757
12/11/08 09:55 PM
12/11/08 09:55 PM
well i did the same as the drawing. radiator first, then the auxillary cooler and back to the tranny.
Re: Torqueflight 727 Cooling Lines #163758
12/12/08 01:58 AM
12/12/08 01:58 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
I did it this way on my '63 mercury as well with the B&M Race cooler and a gauge on the tranny pan for temps. Barely ever got past 150 deg, with a 3000 stall converter and 3.0 rear gears would maybe hit 180 after climibing a 1000ft hill over the course of 2 miles at 55 - 60 mph
Re: Torqueflight 727 Cooling Lines [Re: Alikazam] #163759
12/12/08 01:33 PM
12/12/08 01:33 PM
Louisiana
Louisiana
I got the B&M stacked plate super cooler. I installed it so that the fluid runs through the radiator first. I didn't install a temp gauge and don't know if I will. I have a 2000-2200 stall converter. Hopefully, the fluid will stay cool.
Re: Torqueflight 727 Cooling Lines [Re: duckblind] #163760
12/12/08 01:40 PM
12/12/08 01:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We skip the rad and just use the cooler for race only applications.
