Re: Cam Experts [Re: MR_P_BODY] #1635824
06/20/14 03:16 PM
06/20/14 03:16 PM
western PA
Sb Valiant Offline OP
western PA
I am assuming that the 260/265 @ .050 solid roller cam would peak hp around 7500-7600 rpm with a 344 ci? After reading ou812's post and his 360 with 264 @ .050 peaking out @ 7300 rpms I dunno how much of a difference there would be between my cam specs and engine size vs. his and how the peak numbers would be? I am not exactly sure yet if I will be able to run the solid roller but if I can get alittle feel for where I am at on cam specs it will make it all the easier on another
cam. Thanks
Re: Cam Experts [Re: Sb Valiant] #1635825
06/20/14 03:33 PM
06/20/14 03:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Throw it in, run some 10`s...................It`s NOT that complicated........really.
Re: Cam Experts [Re: Sb Valiant] #1635826
06/20/14 03:40 PM
06/20/14 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
cam. Thanks
Your in the ball park with those numbers.. the 7500-7600
might be a touch high even but close. if you advance
the cam you move the numbers lower in the rpm range
by a couple hundred(depending on how much you advance)
