Page 2 of 3 1 2 3
Re: Replacement for type F trans fluid [Re: dartman366] #1635241
06/18/14 07:08 PM
06/18/14 07:08 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
John Deere . Hy-Gard Hydraulic/Transmission Oil
What the big dogs run in their automatics .
I am going to check into this cause I have a JD dealer just down the street, I did find one 12 bottle case at Advance of their brand which I have used before to get me thru, I wonder if the TCI fluid is similar to the hy-gard as it looked like light motor oil.
Bill, I tried that a few years ago in my trans. With terrible results. The trans had 50 runs on it with Dexron in it. Changed it to the implement fld. 3rd pass the trans started flaring on the 2-3 shift. Pulled it out and found no problems. Even sent the converter back to TA. They said it looked new. Resealed the trans and put Dexron back in it and no problems.
I have been using +4 for the last several years with good results. Just my experience. Jim
Re: Replacement for type F trans fluid [Re: 23T Hemmee] #1635242
06/18/14 07:12 PM
06/18/14 07:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Biggest mistake is equating synthetics with "slipperiness"...it's all about friction modifiers and synthetics have them too.
Re: Replacement for type F trans fluid [Re: dartman366] #1635243
06/18/14 07:18 PM
06/18/14 07:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
it is also slipperyer and the trans guys that I know have told me that under racing conditions clutch's and bands don't grip as well, yes it is great for high heat conditions and street driven vehicles.
I can only speak from my personal experience... but my 100% stock 727 (4 clutch, narrow band drum), tan raybestos stock replacement clutches, used band, and a 4.2 lever) looked nearly perfect after 50+ runs (and 100+ full throttle shifts on the street) at 600~700hp and 3700lbs with only a 2.76~3.23 gear and a trans brake. Couldn't load a trans much harder with worse parts in my opinion.
I use the SUPER F from ATI. CHEAP, and because of the trans blanket, no gear, and loose converter, the trans would get to 270+ degree's nearly every time I raced/drove it.
Pretty hard to argue with that...
http://www.summitracing.com/parts/ati-100001-12/overview/
Re: Replacement for type F trans fluid [Re: John_Kunkel] #1635244
06/18/14 07:21 PM
06/18/14 07:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
same here and that is what John would tell you.
Re: Replacement for type F trans fluid [Re: John_Kunkel] #1635245
06/18/14 07:23 PM
06/18/14 07:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
exactly, I bet most of the hitters are running synthetic
Re: Replacement for type F trans fluid [Re: dizuster] #1635246
06/18/14 07:23 PM
06/18/14 07:23 PM
Renton Washington
Triple Threat Offline
Renton Washington
I use the SUPER F from B&M. CHEAP, and because of the trans blanket, no gear, and loose converter, the trans would get to 270+ degree's nearly every time I raced/drove it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Replacement for type F trans fluid [Re: 23T Hemmee] #1635247
06/18/14 07:24 PM
06/18/14 07:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
"what a crock of crap they told you "
Hate to bust your bubble, but that's exactly why Type F is preferred over synthetics for racing clutch packs.....
well ok then
Re: Replacement for type F trans fluid [Re: Triple Threat] #1635248
06/18/14 07:31 PM
06/18/14 07:31 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah NOT good... I even had 2 trans coolers on the car trying to help that. Went away from the blanket this year, so hopefully it isn't quite so bad.
It was hot enough that it actually melted the plastic thrust washer behind the front pump... and even then it NEVER hurt a clutch.
Re: Replacement for type F trans fluid [Re: dizuster] #1635249
06/18/14 08:17 PM
06/18/14 08:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use CAT. Transmission and drivetrain oil. 10W
I get it by the five Gallon bucket.
Re: Replacement for type F trans fluid [Re: FastmOp] #1635250
06/18/14 10:48 PM
06/18/14 10:48 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I have always used ATF+4 in my torqueflites and it never caused any problems. When I put a powerglide behind my turbo 5.7 I used it too. It caused a bad flare into high gear (1000rpm) I flushed out the +4 and used hydraulic fluid and flare is gone.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Replacement for type F trans fluid [Re: Dave_S] #1635251
06/18/14 10:52 PM
06/18/14 10:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother and I have always used the ATF+4 as we both worked many years at Dodge dealers and we have a nice stock of the ATF+4. But its worked fine for us and the trans and clutches look like new when we tore his down. Ron
Re: Replacement for type F trans fluid [Re: Chris2581] #1635252
06/19/14 08:25 AM
06/19/14 08:25 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Wal-mart type F, cheapest price on oil than anybody else and lucky they always have it in stock
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Replacement for type F trans fluid [Re: slammedR/T] #1635253
06/19/14 11:41 AM
06/19/14 11:41 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use john deer hy-gard purple label in my stuff. MAKE sure if you use it, you have a brass filter NOT a cotton one.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Replacement for type F trans fluid [Re: FastmOp] #1635254
06/19/14 12:27 PM
06/19/14 12:27 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Trans-Synd
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Replacement for type F trans fluid [Re: BloFish] #1635255
06/19/14 02:48 PM
06/19/14 02:48 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
CRT convinced us to switch to Dex II or III. He didn't like the wear properties on the thrust bearings when using type F. Of course, I've been using type F since the 1970's.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Replacement for type F trans fluid [Re: Dads426] #1635256
06/19/14 03:45 PM
06/19/14 03:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
B&M the blue stuff is type F and they have it in stock @ Advance most of the time if not I get from Summit order it one day & the next day its here standard shipping.Not having to pay tax on it more than covers the cost of shipping(they now call it handling fees).
I have not tried the ATI yet but like & use all there other products.
PS its a high $$$ racing transmission & torque converter so I am not gonna try and save a few $$$ using the cheap stuff.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Replacement for type F trans fluid [Re: MRMOPAR622] #1635257
06/21/14 01:56 AM
06/21/14 01:56 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
B&M Trick Shift...5 bucks a quart. The stuff has been around forever. Here in calif. type F is almost non existent and if you do find it, they want over 8 bucks qt. And in my area...wal mart included, Tognotties, parts houses, nobody stocks enough of it. Call me hard headed...I've used type F in all my race stuff for 35 years...if it ain't broke!
Re: Replacement for type F trans fluid [Re: go green] #1635258
06/21/14 08:39 AM
06/21/14 08:39 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've also seen this, not sure if it was John Deere but I was working the top end of a big pro-mod/shoot-out a few weeks ago and this one car would be engulfed in smoke when he turned off the track so I asked him what it was because we first thought he was on fire and it really stunk. He was one of the very few non clutch cars. He said they've switched to hydraulic fluid. It withstands the heat much better than any tranny fluid and he was proving it 3,000 HP boiling it every pass but keeps on running perfectly. And it way cheaper that synthetics.
I haven't ask my tranny builder about it yet so I haven't tried it. My tranny builder did say I was wasting money using synthetic, I argued with him that I use it because I race multiple classes and may go 3 round and never stop at the trailer and he told me they, he's a service manager for a dealership here in town, have done research and testing and adding just one quart of synthetic does just as good as running full synthetic in their tests.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Replacement for type F trans fluid [Re: 383man] #1635259
06/21/14 10:01 AM
06/21/14 10:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Same here.... been using Mopar +4 for ever. Matter of fact when I had that small trans shop over in Lancaster CA (Pro Trans) do some updates on my old Lofgren 727, he said run it!
Re: Replacement for type F trans fluid [Re: J_BODY] #1635260
06/21/14 11:18 AM
06/21/14 11:18 AM
WI
68hemiss Offline
68hemiss  Offline
WI
I just picked up a couple of 727 from my trans guy (longtime mopar racer & race trans builder) and he told me that he had a couple of guys use synthetic have problems recently and he found out that synthetic trans fluid has a shelf life and that it separates over time. He suggests Type F.
Page 2 of 3 1 2 3
