Re: Replacement for type F trans fluid
[Re: BloFish]
#1635263
06/21/14 01:23 PM
06/21/14 01:23 PM
Posts: 21,909 Kirkland, Washington
Pacnorthcuda
Trans-Synd
I purchase that by the barrel at work. It's factory spec for Allison automatics used in class 8 big rigs. I've often wondered how it would perform in smaller units.
[Re: 340B5]
#1635265
06/21/14 04:48 PM
06/21/14 04:48 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think it's the opposite, in a race 727 ATF+4 works OK because of the higher line pressure.
[Re: racerx]
#1635266
06/21/14 05:56 PM
06/21/14 05:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
? Isn't that tractor fluid thicker than trans fluid which robs hp. My
Its basically hyd oil(10 weight) which is what a trans is(a hyd unit) but the trans fluid has different items added to the fluid like anti foaming and cleaners
[Re: loaderpro]
#1635267
08/17/14 05:59 PM
08/17/14 05:59 PM
Posts: 4,125 Mo.
racerx
Mo.
B&M Trick Shift...5 bucks a quart. The stuff has been around forever. Here in calif. type F is almost non existent and if you do find it, they want over 8 bucks qt. And in my area...wal mart included, Tognotties, parts houses, nobody stocks enough of it. Call me hard headed...I've used type F in all my race stuff for 35 years...if it ain't broke!don't try and fix it....Lol
There fixed it for you.
[Re: Chris2581]
#1635270
08/18/14 01:34 AM
08/18/14 01:34 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Wally mart Type F...they always have it here in Florida
^^This
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: 1967dartgt]
#1635272
08/29/14 01:07 AM
08/29/14 01:07 AM
Posts: 4,125 Mo.
racerx
Mo.
I use john deer hy-gard purple label in my stuff. MAKE sure if you use it, you have a brass filter NOT a cotton one.
Why? I run john deere hy-gard and run cotton filter because of my aluminum drums. I have no problems.
To these people running blankets and getting over 230* I would look in to your convertor. I would run a 8" 4800 stall convertor and stroud blanket and would see 180* at end of pass of trans brake.
67dartgt how long have you been running the cotton filter/w aluminum drums? Cause I also run the aluminum drums in my trans and am considering the hy-gard fluids......
