Page 2 of 3 1 2 3
Re: Which distributor is everyone's preference [Re: bigdad] #1634105
06/16/14 12:29 AM
06/16/14 12:29 AM
Locomotion Offline
Locomotion  Offline
I put all Mallory ignition stuff on my race car many years ago and it was basically a "set & forget" deal! HyFire VI AL, 32 series magnetic pick-up distributor and recommended coil. Accel 8.8 wires and plugs as well. I'm really surprised that more people don't run their stuff, considering the stories I hear.
Re: Which distributor is everyone's preference [Re: max_maniac] #1634106
06/16/14 12:34 AM
06/16/14 12:34 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Car currently has basic set up
It has a stock (slightly re-worked) Mopar dist
And, 1st ... the "chrome" box
after 2-3 runs, car would shut off after the run and not re-fire for 5 minutes or so
So, bought another Chrome box
problem fixed ..
Until one night round 7
miss,miss,miss ..
I make it thru the round by dumb luck, hustle back swap the new one for the old one (cold)
Made it another round and then back to hard starting so ..
I bought a rev-e-nator
The claims the make .. hogwash
but, the car worked ok, no issues
But this year again after 3-4 runs
Runs like poo
I put a bag of ice on it between rounds and it run great until high gear and then missed and lost the round
so, I'm swapping batteries
Ign box
dist
wires
coil
and hoping that its gone ..
It will not miss on runs 1-2
3rd ..not often but
4th, 5th round every time
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Which distributor is everyone's preference [Re: Locomotion] #1634107
06/16/14 12:35 AM
06/16/14 12:35 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Why not do a locked out Chrysler electronic distributor (or recurved) in conjunction with an MSD 6AL?
I like it because the Chrysler electronic distributors are stone reliable and you can get parts from any parts store.
I use Taylor wires but will change over to Firecore when these need replaced.
Lots of friends with MSD distributors with severe internal corrosion
issues and I don't care for their wires either..
Swap out the magnetic pickup. Sounds like a similar issue I had..
Re: Which distributor is everyone's preference [Re: GY3] #1634108
06/16/14 12:42 AM
06/16/14 12:42 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
MSD on all my junk.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which distributor is everyone's preference [Re: pittsburghracer] #1634109
06/16/14 12:50 AM
06/16/14 12:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
MSD on all my junk.
No rust, flawless for many years and locked out w/no issues. Of course living out west helps w/the rust issues so many seem to have...........
Re: Which distributor is everyone's preference [Re: Thumperdart] #1634110
06/16/14 08:01 AM
06/16/14 08:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
on my junk I'm using the old Holley Pro Strip Annihilator. shame they went out of production as they are such an easy to configure ignition & reliable as hell. I have a crank trigger controlling the timing & have a gutted ProComp distributor. I did have an MSD Pro Billet distributor but it was huge & had to be removed to get the rocker covers off. for just distributing the spark this Chinese POS works fine, easy to phase & small enough to allow access under the covers. the magnetic trigger inside these things is rubbish but when you not using it these work a treat & cheap!
Re: Which distributor is everyone's preference [Re: Thumperdart] #1634111
06/16/14 08:20 AM
06/16/14 08:20 AM
Q
Quicktree Offline
Quicktree  Offline
Q
MSD on all my junk.
I have one nearly 10 years old and still looks like new
Re: Which distributor is everyone's preference [Re: bigdad] #1634112
06/16/14 09:40 AM
06/16/14 09:40 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
BigDad,
Sounds almost like you only just need to find a cooler location to mount your ECU.
Where is it mounted now?
Re: Which distributor is everyone's preference [Re: BigBlockMopar] #1634113
06/16/14 09:45 AM
06/16/14 09:45 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Inside car, on inner floorboard ..
I don't think heat is a issue, its mounted on a stand for an air gap also
Possible yes but, doubtful..
I think we can all agree the ol chrome boxes have never been great , and with them being made off shore now they are of less quality than ever
And, I'm not much of a fan of the Rev-n-nator either .
Re: Which distributor is everyone's preference [Re: bigdad] #1634114
06/16/14 10:07 AM
06/16/14 10:07 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have an MSD ditributor (not a dizzy). Crane HI6 box. NO problems in 7 years. My buddy has MSD boxes and he has had problems. May be that he doesn't solder the wire connections, just crimps them. When I had my race only engine I was turning 6800 in the lights. Now with my street engine I shift a 6000 and ease through at 4800.
Re: Which distributor is everyone's preference [Re: babarracuda] #1634115
06/16/14 11:07 AM
06/16/14 11:07 AM
The Netherlands
The Netherlands
Doubtful if the ECU gets enough cooling this way, but then again, they were supposed to operate good in an engine bay aswell.
I personally would like to create some 'forced' cooling with either an extra little fan blowing at it, or put it in a place where it gets fresh air, like the front of the radiator support.
I've ran a Mopar gold ECU once which lasted exactly 1 run. On the far end of the track the engine barely kept running and was just able to make it back to the pits.
It was however mounted high on the front of the rad. support frame.
Re: Which distributor is everyone's preference [Re: BigBlockMopar] #1634116
06/16/14 11:16 AM
06/16/14 11:16 AM
Az
Crizila Offline
Crizila  Offline
Az
I have been running a D.U.I. for many years now on my sm blk. I like the 1 wire hook up all inclusive thing. Makes life simpler. They make a smaller cap version for BB valve cover clearance ( external coil ). Run they're jacketed 8MM wires also. I run a dedicated 12 gauge wire to it which keeps it supplied with 14 volts and output is 55K.
Fastest 300
Re: Which distributor is everyone's preference [Re: BigBlockMopar] #1634117
06/16/14 11:32 AM
06/16/14 11:32 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
That kinda shoots the needing air theory then cause,not many places where it could see more air circulation than that ?
I think those Mopar(style) boxes are just plain lousy
Re: Which distributor is everyone's preference [Re: bigdad] #1634118
06/16/14 11:36 AM
06/16/14 11:36 AM
PA.
"Little"John
"Little"John
PA.
When I used to use the mopar boxes I always had two mounted in my Duster. One to get there and one to get home. I'm serious I always had two side by side just in case and the just in case came into play once in awhile.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Which distributor is everyone's preference [Re: bigdad] #1634119
06/16/14 11:50 AM
06/16/14 11:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Had the same issues with the "chrome" box on the Mirada long ago. Even moved the ecu to the front of the rad support where it would get airflow around it....it would still act up on occasion. Switched to MSD 6AL and Pro Billet distributer and never looked back. The distrib was still a tight fit with the stage VI heads and MP valve covers. Had to trim a bit, but from what I've gathered....the old boat is still running. I liked the MSD distributer. Pop off the cap and rotor and it was easily adjusted with the supplied springs and offset spacers.
Re: Which distributor is everyone's preference [Re: pittsburghracer] #1634120
06/16/14 12:31 PM
06/16/14 12:31 PM
The Netherlands
The Netherlands
I'm running 2 ECU's mounted right next to eachother aswell in my daily '73.
Re: Which distributor is everyone's preference [Re: BigBlockMopar] #1634121
06/16/14 12:45 PM
06/16/14 12:45 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
Firecore dizzy here. I like it.
Re: Which distributor is everyone's preference [Re: VernMotor] #1634122
06/16/14 12:54 PM
06/16/14 12:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
MSD Dizzy here and its been good to me so far. Its coming out this winter and I am doing away with the carburetor and the MSD and going fuel injection with coil on plug.
68 Barracuda Formula S 340
Re: Which distributor is everyone's preference [Re: Bad340fish] #1634123
06/16/14 12:58 PM
06/16/14 12:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
MSD here with a crank trigger, and yes its rusty.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which distributor is everyone's preference [Re: GY3] #1634124
06/16/14 05:23 PM
06/16/14 05:23 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Firecore MEchanical Distributor, Firecore Ignition Box, Firecore Mini-Coil, Firecore50 Ignition Wires. Zero ignition System worries.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Page 2 of 3 1 2 3
