Page 2 of 3 1 2 3
Re: Duster rebuild Indy 655ci [Re: Bigcube] #1633771
06/15/14 09:31 AM
06/15/14 09:31 AM
Columbus Ohio
Moore & Moore Offline OP
Columbus Ohio
The heads are Indy 600-13X We bought another set this spring and will be doing some flow comparing this week between the 2 sets.
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633772
06/15/14 12:38 PM
06/15/14 12:38 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I ran this motor some last year. It was in Jeff Hurst and Chuck Andersons dragster's and ran 6.80-7.20's depending weather they ran motor or sprayed. I had some issues with the Pro Systems carbs and we pulled it out after the Norwalk race. We are putting new rods, pistons, lifters, valves and valve springs in. I also bought a Neal Chance convertor to try and see how it preforms against my ATI and Coan. The block is a 4.84 bore spacing. I should have it running next month.
I'm very interested in what these heads are capable of. Was the Hurst engine 655?
Re: Duster rebuild Indy 655ci [Re: camastomcat] #1633773
06/15/14 03:26 PM
06/15/14 03:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Gene Nagy's Stratus is running 4.60's at PRP (no adder) with those heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633774
06/15/14 11:03 PM
06/15/14 11:03 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Block #2
Jack
What oils the distributor oil pump drive on these blocks? It is closed off from the liftergaley, so no splash oiling for it.
Thanks jerry
Old Geezer Racing
Re: Duster rebuild Indy 655ci [Re: SCATPACK 1] #1633775
06/16/14 12:03 AM
06/16/14 12:03 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
very nice!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633776
06/16/14 12:28 PM
06/16/14 12:28 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Was those the single blade carbs?
Re: Duster rebuild Indy 655ci [Re: supercomp] #1633777
06/16/14 04:59 PM
06/16/14 04:59 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Man Jack that crank of yours is purty I am sure you here that all the time...right
If that were me it would have rolled off the tailgate while I was taking the photo
Re: Duster rebuild Indy 655ci [Re: 340RICK] #1633778
06/16/14 05:14 PM
06/16/14 05:14 PM
PA.
"Little"John
"Little"John
PA.
That tailgate of Jacks is famous. Its in most of his for sale ads.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Duster rebuild Indy 655ci [Re: pittsburghracer] #1633779
06/16/14 08:53 PM
06/16/14 08:53 PM
Columbus Ohio
Columbus Ohio
Here are some answers to some of the questions asked earlier.
1 The block is a 4.84 bore spacing
2 The Hurst engine was a 655ci
3 The oil pump drive shaft gets oil thrown on it from the cam and crankshaft
4 The carbs are Pro-System Nitrous Pro-IV(not single blade)
5 The tailgate is the best table I have Lol
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633780
06/17/14 01:47 AM
06/17/14 01:47 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
looks like youve been to the jewelry store jack! did you ever sell that koleno block?
SFI 25.5 depends,no leak,even at 213 mph....
Re: Duster rebuild Indy 655ci [Re: dakotawilly] #1633781
06/17/14 10:26 PM
06/17/14 10:26 PM
Columbus Ohio
Columbus Ohio
Here is a photo of the open area below the oil pump drive.
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633782
06/17/14 10:30 PM
06/17/14 10:30 PM
Columbus Ohio
Columbus Ohio
The block was honed at Wasserbeck Speed Shop on a Sunnen SV-10 Diamond hone. Here is a photo of the machine setup with RPM, Speed and X-hatch angle. I will post hone finish surface specs tomorrow.
Re: Duster rebuild Indy 655ci [Re: 340RICK] #1633783
06/17/14 11:16 PM
06/17/14 11:16 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I am impressed that it uses 4 crankshafts
Were you going to run in the nostalgia pro stock?
Re: Duster rebuild Indy 655ci [Re: maxie] #1633784
06/18/14 12:41 AM
06/18/14 12:41 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: Duster rebuild Indy 655ci [Re: pittsburghracer] #1633785
06/18/14 03:19 PM
06/18/14 03:19 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
im hoping to see these number with my daytona and my 655 with dual sv1s...made 1 pass last weekend and went 5.35@131 with some more tuning and possibly a convetor adjustment. .4.80s should be in reach....
Re: Duster rebuild Indy 655ci [Re: 2QUICK4U] #1633786
06/18/14 11:05 PM
06/18/14 11:05 PM
Columbus Ohio
Columbus Ohio
Made some progress tonight after work. Got the rods and pistons in. I put the cam in and hope to get it degreed in tomorrow night. It is a Cam Motion 55mm with 4/7 swap. The specs with 1.8 rockers are .900/.850 lift and 283/303 duration R117.
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633787
01/12/15 08:30 PM
01/12/15 08:30 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Any more news?
Re: Duster rebuild Indy 655ci [Re: Tig] #1633788
01/12/15 10:44 PM
01/12/15 10:44 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
that crank coating looks very interesting!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633789
01/13/15 02:03 AM
01/13/15 02:03 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Nice stuff
Re: Duster rebuild Indy 655ci [Re: Moore & Moore] #1633790
01/13/15 02:14 AM
01/13/15 02:14 AM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Jack parts look great glad to hear you're getting it put together. The tailgate is good as well. Brawler
Page 2 of 3 1 2 3
