Re: Stripping Down an 8 3/4
[Re: BigBlockMopar]
#1633631
06/15/14 01:13 PM
06/15/14 01:13 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Remove all the nuts, Tap the snout of the housing left & right with a rubber hammer or large block of wood. This will break the bond of the gasket and the 3rd member can be lifted right out.
For 'easy' carrying of the 3rd member, put the U-bolt of an exhaust clamp through the top bolthole nearest to the large gear and thread a nut on it so it won't slip out. This way you'll have a nice balanced handle to lift the 3rd member by and carry it around, posing to the chicks across the street or something. ![](/ubbthreads/images/graemlins/stirthepot.gif)
I believe I have a rubber mallet at home. Lol. I mean, I can almost carry the whole differential drum-to-drum by myself, I can't see why I can't do a carrier. ![](/ubbthreads/images/graemlins/shruggy.gif)
Prepping an 8 3/4 for Paint or Powdercoating
[Re: MuuMuu101]
#1633634
06/18/14 01:47 AM
06/18/14 01:47 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I got it out. I was able to get a large enough gap to slide a screwdriver through and then just kept inching it with more screwdrivers till I was able to pull it off. Now it's time to prep it for paint or powdercoating. Which would be better and what's the best way of cleaning all the oil from it?
Re: Prepping an 8 3/4 for Paint or Powdercoating
[Re: MuuMuu101]
#1633635
06/18/14 06:39 PM
06/18/14 06:39 PM
RapidRobert
A car wash wand would be a very good start for the cleaning, especially the inside (get them seals out of there first which I assume you have done/just checking)
[Re: RapidRobert]
#1633636
06/18/14 08:33 PM
06/18/14 08:33 PM
Posts: 4,323 NY NY
340duster340
NY NY
If you powder coat it make sure they do not blast inside the housing or hit the gasket surfaces with the sand blaster.
Personally, I Prefer paint over coating suspension parts because it can be touched up.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: MuuMuu101]
#1633640
06/19/14 02:51 AM
06/19/14 02:51 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The seals are just inside of where the bearing fit..
I am truckless..
[Re: MuuMuu101]
#1633641
06/19/14 11:56 PM
06/19/14 11:56 PM
Posts: 7,664 IN
ahy
IN
Ok, so paint is better the powdercoating. That's good because it's something I can do myself and not have to wait or pay someone to do. Now, is it better to clean and paint the outside of the housing before assembly or after? Also, where are the seals and how do I remove them? Thanks for all your help.
Lots of ways to remove the seals. A long wood dowel or broom stick from the opposite side works well with no scratches.
[Re: ahy]
#1633642
06/20/14 03:34 AM
06/20/14 03:34 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So just stick the broom stick through one side to knock out the opposing seal on the other side?
[Re: MuuMuu101]
#1633643
06/20/14 04:28 AM
06/20/14 04:28 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
On mine I'll chemically remove the rust, but what's the best way to fill the rust pits?
[Re: kentj340]
#1633645
06/20/14 10:29 AM
06/20/14 10:29 AM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
High build primer will work but its a lot of material. I used one of the layered sandpaper wheels on a grinder to minimize the pitting, then followed it up with a skim of body putty. Prime it good, sand and paint. Gloss black sucks to work with on suspension parts. Use a nice satin black paint and it will always look good. I had mine mixed up at a local paint store and then put into spray bombs. I used spray on bed liner on the one in my other car. I'm not sure I don't like it better than the painted one. ![](/ubbthreads/images/graemlins/thumbs.gif)
...FAFO...
[Re: skicker]
#1633646
06/20/14 12:28 PM
06/20/14 12:28 PM
Posts: 166 MINNESOTA
BRONZEBEE
MINNESOTA
Take it to an engine shop and have them clean it, it will be clean inside and out. Local engine shop charged me $20 couple years ago. If you sandblast it for powder coating you will never get all the all the sand out! with out cleaning it first. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: kentj340]
#1633647
06/20/14 08:39 PM
06/20/14 08:39 PM
Posts: 7,664 IN
ahy
IN
Agree the primer will fill pits. Sand and use rust stop primer first then high build. Sand and prime and sand again until it is as smooth as you want it. Satin looks good and is pretty forgiving. Agree stay away from flat.
[Re: MuuMuu101]
#1633649
06/22/14 05:36 PM
06/22/14 05:36 PM
kentj340
Cut and Shoot, TX
The original housing was painted at the factory naked, because you can see paint overspray inside. After that the unpainted backing plates, backing plate fasteners, and pig were mounted.
The backing plates and fasteners on my '69 8 3/4 are phosphated, not painted. And, of course, the original pig was bare and unpainted.
