Re: Swap 3.23 to 3.55 rear end... Is it worth it?
[Re: BigBlockMopar]
#1633538
06/14/14 09:29 PM
06/14/14 09:29 PM
Posts: 464 KY
Telvis
KY
Maybe I will just add the 904 lower gearset and keep the 3:23. It will be the lowest cost option for sure
That's King Weenie to you!
[Re: 68_661charger]
#1633541
06/14/14 11:13 PM
06/14/14 11:13 PM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Go for it... I experienced the following combinations: 1) 2.7x (with low gear ratio 904) 2) 2.94 (with low gear ratio 904) 3) 3.55 (with 727, 2300 stall converter) 4) 3.91 (with 727, 2800 stall converter, but moved to a 4000 Dynamic right now due to the powertrain combo) A 'day-night' difference between 2 & 3 and again between 3 & 4. If you can tollerate the higher RPM on the highway (c'mon...not that bad either...) you'll be fine, because when you're in town there just ain't no greater feeling that literally leaving just about anything else behind you...should the need arise... Now...if you want to cruise as much as you can, and want the motor to just purr along then 3.55 is probably as low as you want to go.
[Re: Telvis]
#1633542
06/14/14 11:35 PM
06/14/14 11:35 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
It's difficult for most of us to have it all. I think the 3.23.is a great gear. Right now I have 3.55s behind an OD trans and it is a nice combo for the street. 3.91s are too low without an OD. I've had all of them for the street and if the motor is strong 3.23 sure grip is hard to beat. I've never modded the trans gears but that sounds like a nice option to start with. With a 3.55/904 combo you'll be somewhere around 2700-2800 rpm at 70 mph. My 3.55/A500 combo is 2000-2100 rpm at 70. BTW my tires are 28.5" tall.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Telvis]
#1633544
06/14/14 11:50 PM
06/14/14 11:50 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
If you do the math on the low gear sets, stock and low low gear sets, you sould probally have much more low gear multiplication of torque in 1st gear with the 3.23 and the low gear than with the standard ratio low gear set and the 3.55. My calculator batterys just went tents up just now so I can't , won't, do the math for you. Multiply the low gear ratio times the rear gear ratio to get the starting line ratio I borrowed the house solar powered calcultor, the 3.23 with a 2.44 low gear ratio, standard 727 gears equals 7.88 in first gear, the same low gear set and the 3.55 rear gears equals 8.66. The low gear set in the 727 is 2.77 if my memory is correct so the 3.23 with them is 8.947 or rounded up is 8.95 The low gear set with the 3.55 would be 9.83 I like using a 1st gear low gear set like that I use to use them in my 1963 M.W. stocker in NHRA stock class racing I'm building a new 4 speed street car, it wll have a NP833 O.D stick tranny in it, they come with a 3.09 low gear set with .64 O.D. in overdrive, I'm going to use a set of 3.54 gears in the Dana 60 with a short set of rear tires, hopefully 275x60x15, or what ever will fit in a 1966 Dodge Coronet Deluxe It pays to think before acting Especially on car parts and combinations
[Re: Cab_Burge]
#1633545
06/14/14 11:59 PM
06/14/14 11:59 PM
Posts: 464 KY
Telvis
KY
Great information! It confirms that the lower transmission gear set is definitely the way to go. Now, if I could find an A500 to swap out I could get the lower low gear and an overdrive. I could have the 3:55 or even the 3:91 gears and still have great highway manners. Even if I don't find an A500 I can still swap the 904 gears and keep the 3:23 set I have and do pretty well on takeoff. Those aren't bad options either way. Thanks for the info! I think this is what the guy from Turbo Action was trying to explain. It makes a lot of sense.
[Re: Telvis]
#1633546
06/15/14 02:48 AM
06/15/14 02:48 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Can't talk about maths, but I did it at the same time went with SG replacing open differential and I'm enjoining it without loose on daily driving on streets
Did it with still stock 400 engine and 727 on 255/60-15, now stroked with 175K MP converter and even more fun. I bet with a better TC will be way better, but not funds for that now.
[Re: Telvis]
#1633554
06/17/14 06:19 PM
06/17/14 06:19 PM
Posts: 1,120 MassHole Central
rtman
MassHole Central
Had 3.55s in my '70 Charger R/T. My conclusion was that the 3.55s weren't particularly good at anything. Didn't give the blistering low-end torque you really crave (like with 3.91s or 4.10s) and weren't as smooth on the highway as 3.23s or 2.76s. I went back to factory 3.23s. The car liked them better (heavy car with AT with stock converter). For my , optimal is a low gear and an OD, but that's pricey. I'd swap out the converter before changing the gearing. Good luck.
