Re: Indy Maxx aluminum block concerns?
[Re: 4404dart]
#163299
12/06/08 02:20 PM
12/06/08 02:20 PM
Posts: 6,295 U.S.
moparniac
U.S.
not a problen on my buddies down at the shop.. goes 8's on motor but needed alot of pushrod clearance...
Mopar Performance
[Re: jamesc]
#163305
12/06/08 09:43 PM
12/06/08 09:43 PM
I get almost 1100hp out of my 588 there have been zero problems with the block.
[Re: plycuda]
#163307
12/06/08 11:09 PM
12/06/08 11:09 PM
Posts: 778 Sherwood park, Alberta.
go green
Been there done that . Oil drain back is a problem with them. Just put a 2 " window by the cam gear wall and connect the 8 holes in the oil gallery. Part of the problem of the block is that any positive crank case pressure has to pass through those 8 little holes. ( consequently the oil has to go them going the other direction ).
[Re: jamesc]
#163308
12/06/08 11:39 PM
12/06/08 11:39 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
Hmmm...i noticed the cam bearings in my new KB block had roll pins in them. i was thinking it was for oil restriction but maybe it's to keep them from turning...or both. anyone know for sure?
I am also going to an aluminum rod, and those have to have a bearing with a hole because they're pinned. I'm seeing a trend? But some can use the blocks without modifying them? Not sure about your KB block, but I'm thinking the pins are for movement? Thanks.
[Re: go green]
#163311
12/06/08 11:46 PM
12/06/08 11:46 PM
4404dart
Colorado,U.S.A
Thanks. That's what this guy was telling me. They were on the dyno, took the access plate off the valley cover, and the lifter valley was full of oil? I was worried about strength connecting the holes?
[Re: go green]
#163312
12/06/08 11:57 PM
12/06/08 11:57 PM
Posts: 2,432 NorCal
RylisPro
NorCal
would you still have that problem if used with a dry sump pump? gonna use one on mine
[Re: RylisPro]
#163313
12/07/08 12:08 AM
12/07/08 12:08 AM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Hmmm so the vacuum pump is usually sucking from the valve cover sucking up through those little holes, then the dry sump is sucking down, the oil won;t know where to go.
I've got a KB block right now and there is plenty of room for the oil to drain back down. When this new engine build is done it will have a dry sump and vacumm pump:)
With the Indy block i would open up the holes bigger. Just IMO
[Re: RylisPro]
#163314
12/07/08 12:11 AM
12/07/08 12:11 AM
Posts: 4,774 On the parachute mount
n20mstr
i have an indy block,
my cam bearing were very tight, i put in the cam and could not turn it at all, i had to scrape them all to get the cam to turn easy, 200 passes so far no problems,
on the drain back, i would rather drill and tap the rear of the heads like a B! to get the oil back to the pan, rather than open those holes. Id rather route the oil around the rotating assemble than dump MORE oil on top of it.... Like i say, my block has 200 passes on the first build up of it, its coming out now so ill see how the bearings look, i dont have a drainback problem that im aware of.
....BAD A$$ STREET CAR.....
