Re: 77 D100 heater core
[Re: YellowD100]
#1631732
06/10/14 06:02 PM
06/10/14 06:02 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
have a new replacement standing by to replace the old leaky one...
I am truckless..
[Re: YellowD100]
#1631735
06/16/14 12:45 PM
06/16/14 12:45 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
The heater core in my 1977 D100 (no A/C) started leaking yesterday, and completely soaked my carpet. Before I attempt to take everything apart to fix the problem, does anyone have any tips for what I need to look out for when I take it apart? Any suggestions would be appreciated.
I have a complete firewall that I from a 77 you can come get or practice on. Still has the heater box. Going to scrap soon.
Pretty simple too. Depending on brand, the replacement heater core fills the whole plate. At least on my 72
[Re: 76dodgeboy]
#1631737
06/16/14 06:19 PM
06/16/14 06:19 PM
magnum440d100
woodcrest, CA
My 73 the nuts on the engine bay side didnt all come off. So I had to chnge it with the heater box installed. Far right side will have a couple screws that can only be removed if the box is. I broke it off. Didnt cause any real damage and went back together just fine.
Ah. My 72 I was able to swap cores with it installed. Took every little screw out. I don't remember having to break any screws though Also replaced the foam while I was at it
[Re: magnum440d100]
#1631738
06/16/14 08:53 PM
06/16/14 08:53 PM
Posts: 4,156 Canada -- Posts: 4034 -Registe...
5thAve
I did mine that way too with my 79 and I had no problem getting all the screws out without breaking anything. My new heater core was almost the size of the plate too and a couple of the screw holes didn't line up so I had to cut them a bit.
[Re: 77ProStreet]
#1631740
06/27/14 09:04 PM
06/27/14 09:04 PM
Posts: 24 Pasadena, CA
YellowD100
Pasadena, CA
Thank you everyone for all of the advice. Unfortunately work is really busy right now ant the truck is just sitting in the garage. Bypassing the heater all together was my first thought, and probably will still do that for the short term. Hopefully I will be able to fix this by the end of next month.
magnum440d100 Thanks for the offer, I am tempted to take you up on it, but would not be able to get out there for a few weeks.
********************************** 1977 D-100 Adventurer SE Utiline 360 727 2010 Ram 1500 CrewCab 5.7 4x4
[Re: YellowD100]
#1631741
10/20/14 07:05 PM
10/20/14 07:05 PM
YellowD100
Pasadena, CA
I finally had time to remove the heater core. Attached is a picture of the heater vent door.
Does anyone know where I can get a replacement for the foam that covers this to seal the air out, or an idea for a replacement? As it is now it crumbles to the touch.
[Re: Golden-Arm]
#1631744
10/22/14 07:04 PM
10/22/14 07:04 PM
YellowD100
Pasadena, CA
Thanks for the ideas. I am also talking with Jim from Detroit Muscle Technologies. He is in the process of making a complete set of gaskets for these heater boxes.
